I am putting together the home video files, using an MP3 song as the soundtrack file in Womble Mpeg Video Wizard DVD. However, as I'm trying to use Cold Play's Viva La Vida (mp3 that I purchased from Walmart.com for $0.74), Womble freezes plugging the CPU at 100% indefinitely. I can only stop the process (process explorer) to get back to normal.
I thought maybe BeSweet might be able to handle the conversion then to MP2 (I'm using BeLight GUI) for the file, but that has the same issue--pegs the CPU at 100% with no indication of anything happening.
Yet, Windows Media Player plays the MP3 file just fine, no issues.
The process (both Womble MVW and BeSweet) work fine with other MP3 files I bought at the same time. Does anyone have any ideas on how to make this file work, and any way to "fix" it?
Thanks!
Tim
It looked like that worked, albeit it felt a little sketchy. However, the resulting wav file was like 50k (from source MP3 of 7.5 MB. It isn't anything like expected.
Here's my log file:
BeSweet v1.4 by DSPguru.
Using hip.dll v1.13 by Myers Carpenter <myers@users.sf.net>
Logging start : 12/19/08 , 20:58:04.
BeSweet.exe -core( -input C:\Documents and Settings\Tim\My Documents\My Music\new\Coldplay-Viva_La_Vida_.mp3 -output C:\Documents and Settings\Tim\My Documents\My Music\new\Coldplay-Viva_La_Vida_.wav -2ch -logfile C:\Documents and Settings\Tim\My Documents\My Music\new\Coldplay-Viva_La_Vida_.log ) -azid( -s stereo -c normal -L -3db ) -ota( -hybridgain )
[00:00:00:000] +------- BeSweet -----
[00:00:00:000] | Input : C:\Documents and Settings\Tim\My Documents\My Music\new\Coldplay-Viva_La_Vida_.mp3
[00:00:00:000] | Output: C:\Documents and Settings\Tim\My Documents\My Music\new\Coldplay-Viva_La_Vida_.wav
[00:00:00:000] | Floating-Point Process: No
[00:00:00:000] | Source Sample-Rate: 44.1KHz
[00:00:00:000] +---------------------
[00:00:00:052] Stream error : Sync found after 140485 bytes
[00:04:01:556] Conversion Completed !
[00:04:01:556] Actual Avg. Bitrate : 1kbps
[00:01:06:000] <-- Transcoding Duration
Logging ends : 12/19/08 , 20:59:10. -
i'm guessing it's a damaged mp3. try mp3repair on a copy of it.
http://www.drtag.de/en/downloads_mp3rt.htm--
That's possible of course, but I'd not bet many bucks on itOriginally Posted by aedipuss
A couple of years ago I found some "mysteriously-encoded" MP3s which
could not be decompressed at all by the LAME dll, nor by Nero 5 and 6.
Only the CLI-program lame.exe was capable of dealing with them.
Transcode A DivX
By Anakin in forum Video ConversionReplies: 4Last Post: 19th Nov 2008, 07:29 -
Transcode for Dreambox
By dreams in forum Video ConversionReplies: 4Last Post: 13th Oct 2008, 06:50 -
Help I can't Transcode AC3 to Anything
By Tyrel919 in forum AudioReplies: 10Last Post: 22nd May 2008, 20:01 -
Can you partition a harddrive based mp3 player? - ISSUE FIXED!!!!!
By yoda313 in forum Off topicReplies: 0Last Post: 27th Jul 2007, 18:14 -
MP3 -> CD+R issue
By coody in forum DVD RippingReplies: 25Last Post: 25th Jul 2007, 12:52
