  1. Hi, Just bought myself a Sony BDP S350, and 5.1 speakers. I have right and left audio out on both my tv and the blu-ray player. What do I need to connect the six (three red, three white) phono plugs to either the tv or player? AV receiver? Some kind out signal splitter?
    Bill
    Oct 2005
    666th portal
    AV receiver?
    yes
  3. Cheers. Any idea of prices?
    Bill
    Oct 2005
    666th portal
    in the usa maybe $150 -> thousands. depends on features, wattage, amp class.
    look at a few local shops like best buy, circuit city to see what you need/want.
  5. Cheers again.
    Bill
  6. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Assuming your Blu-Ray player and TV are connected via HDMI, take a look at AVR's with HDMI connectivity. The Onkyo 606 is a good low end AVR with HDMI.
    Google is your Friend
  7. Banned
    Freedonia
    aedipuss is right, but you definitely need to know that the less you pay, the less it has. You'll easily pay $300-400 or more for a good receiver with HDMI inputs/outputs, which you're probably going to want at some point. Krispy Kritter's suggestion is within the range I'm talking about.
