  1. Member Lippy Lipstick's Avatar
    Mar 2008
    Between the tulips
    I want to use Canopus Procoder 3 to make autostart-DVD's. So far so good,
    but how can I simply add chapters every, let's say 5 or 10 minutes?
    Can't find any info in the helpfile nor on the internet. Anyone?
    Oct 2005
    666th portal
    chapters are added in the authoring stage, procoder is just an encoder.
  3. Member Lippy Lipstick's Avatar
    Mar 2008
    Between the tulips
    I know, but Procoder is able to make a simple DVD-structure, which
    then can be burned to disc. That's all I need, the only thing I miss is
    simple chaptering every 5 or 10 minutes and I don't want to face
    another authoring-round if I already have a DVD-structure.
    Apr 2004
    Miskatonic U
    Under the VOB output settings there is an option, ticked by default, that says Use Marker settings. Untick this and you can set an alternate method for chapter stops. Choose periodic (should be the default value), then set you interval in the filed below in minutes.
    Read my blog here.
  5. Member Lippy Lipstick's Avatar
    Mar 2008
    Between the tulips
    PROBLEM SOLVED! Thanks a million, you're the hero.
    Just tried it by unclicking the marker point and suddenly
    the chapter-option appeared!
    You made me a happy man
