I have converted about 100 .mts files into .avi using this batch file:
https://forum.videohelp.com/topic347139.html
But I now want to join all those 100 files into one .avi file.
I have tried using VirtualDub, but I get this error message when I try to open my files with it:
"Couldn't locate decompressor for format 'xvid' (unknown)"
"VirtualDub requires a Video for Windows (FVW) compatible codec to decompress video."
Is there anyway to fix that?
I have also tried using a software called Avi Joiner 1.0, but all that does is create a file that cannot be played. It does join files when I do 2-3 files, but when I try to join more than that it produces a corrupted file...
How can I join these files together?
Results 1 to 12 of 12
Do you have the Xvid codec installed? I would try that first. I'm most familiar with VD. As long as your AVIs are numbered sequentially, and 'Automatically load linked segments' is checked at the bottom of the page, it should work automatically.
I had the latest K-Lite Codec Full pack installed and just now I installed xvid codec separately, but I'm still getting the same error. "Automatically load linked segments" is checked. I can open other files in VD, but not these AVIs for some reason...
What should I do? -
Managed to figure it out by myself. Xvid decoder was disabled in ffdshow VFW Interface. Changed it to xvid and it works now...
Will try to join these files now...
--edit--
It works fine, but is there anyway I can add more than 1 file at a time? Coz adding 100 files one by one will take ages...
--edit again--
I think I figured it out again. When u add the 2nd file u get an option to "Autodetect additional segments by filename". So all I have to do is rename all those 100 files using app like Bulk Rename Utility and VD should add all 100 files automatically, right? -
Sounds right.
I haven't done that for a while. All of the video needs to be the same format and specification and numbered sequentially.
BTW, just about everyone here advises strongly against using the K-Lite or other codec packs because all the problems and damages they can cause to a system and existing codecs.
If you have the XviD codec installed then you don't need to enable in ffdshow. Something is screwing up the XviD codec.
I managed to join all 100 files together, but the audio at the end got out of sync. I found another guide how to fix that using Interleaving and I think it did the job...
I always thought that K-Lite Codec was the best option. I have used it for a few years now and had no problems at all, but thinking about it, I have never encoded any videos myself...
So what would be the best option for codecs? Install each codec one by one separately? Can u advise me what codecs I need? -
Yes, the best option is to install only the codecs you need, as you need them. If you are encoding, then you know what you need. If you are decoding, use Mediainfo or g-spot to tell you what file uses, and then install just those codecs.
If you need a general purpose playback codec you have a couple of choices. You can use a player like VLC or The KM Player that have most codecs you need already built in. Only they can use them, but they are good players anyway, and make life much easier. If you are wedded to WMP (yuck), or Media Player Classic, then FFDShow will get most things playing.Read my blog here.
ok, thanks a lot for the advice, guns1inger. I will give it a go and try installing codecs separately, although installing just one bundle sounds a lot easier...
I wrote a program that joins mts files together. Several people have used it and report that there are no dropped frames and that the output is flawless. I do a binary copy from the source .mts files to a new file. It's quick and easy to use. Here's the link:
https://sites.google.com/site/mtsfilejoiner/Hopelessly lost, but making good time! -
Couldn't locate decompressor for format 'XVID' (unknown)
Big Problem:
It gives me the error code:
VirtualDub requires a Video for Windows (VFW) compatible codec to decompress. DirectShow codecs, such as those used by Windows Media Player, are not suitable."
and I already installed some codecs that I thought were going to work.
Quick fix:
because fourcc is "xvid" not "XVID"
change "xvid" in "XVID" and works -
What Xvid codec did you install ? If you install the one from the Tools section on this site, you should have no problems.
Read my blog here.
How to join back 2 xvid files encode by autogk
By warresg in forum DVD RippingReplies: 1Last Post: 6th Nov 2010, 03:59 -
Join AVI files??
By bagmand22 in forum Authoring (VCD/SVCD)Replies: 16Last Post: 14th Feb 2010, 04:42 -
join several avi files
By hilario in forum EditingReplies: 2Last Post: 13th Nov 2009, 13:49 -
LOAD CLICK AND LOW SOUND at join of 2 avi xvid ac3 using vitualdub
By hawklight in forum EditingReplies: 0Last Post: 15th Jul 2007, 09:44 -
Using Submerge to Join avi Files to srt Files: Problems with Export
By TiggyWink in forum MacReplies: 1Last Post: 26th Jun 2007, 09:16
