Hello, I'm encoding alot of music video dvds, promoes and stuff like that. The quality is usually not great but ok.. this is the encoding string I use.
mencoder.exe" vid.vob -vf yadif=0,crop=688:352:16:62 -oac mp3lame -lameopts preset=extreme -ovc x264 -x264encopts crf=25ubq=5:bframes=3:b_pyramid:weight_b:threads=auto
ass=1 -of lavf -lavfopts format=mp4 -o vid.mp4"
this usually give me ~60fps encoded and I'd say it's fairly fast. But I'd like some input and maybe tips of things I should try.. I'd would like more quality and I'd also like to know if this is very low quality in your eyes..
thx
//triptec
okay, tried it, bigger files not that much quality gain I'd say, but I got no good way to compare the output (any tips? see video beside another?), how about -vf yadif vs pullup snad so on? and what would improve quality without making bigger files, just timeconsuming?
quality generally comes from bitrate (or lack thereof). The higher the bitrate, the better the quality (assuming comparison of the same good source), however higher bitrate means bigger file.
Unless your source has major noise issues or other problems which be fixed by filtering before encoding, there is little you can do to improve, and certainly not without getting bigger files.Read my blog here.
Set an specific GOP with mencoder h.264 x264encopts and lavcopts
By lacp in forum Video ConversionReplies: 0Last Post: 14th Feb 2012, 06:07 -
capture VHS with Virtualdub , color tweaks
By smartel in forum Capturing and VCRReplies: 10Last Post: 19th May 2011, 07:34 -
Canon Vixia HG21 need setting tweaks...
By Heyjoojoo in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 27th Jan 2010, 13:35 -
Canopus ADVC 300: best settings / tweaks ?
By fabweb in forum Capturing and VCRReplies: 3Last Post: 12th Sep 2007, 06:34
