Results 1 to 10 of 10
    Aug 2005
    USA
    I'm trying to learn to use AVI.NET. All seemed to be going OK until I clicked START. A few seconds later the program terminated with a runtime error from windows. Anybody have any ideas what happened and how to fix it?
    Apr 2004
    Miskatonic U
    Do you have the right version of .Net installed ?
    Read my blog here.
    Aug 2005
    USA
    I have recently installed a new HDD and spent some time allowing XP to upgrade itself so I should have whatever is current. Is there a "wrong" version of .NET?
    Apr 2004
    Miskatonic U
    There are several versions of .net, and they are all optional in XP, while .net 3 is installed with Vista. AVI.net appears to need .net 2.5, which you will have to download from Microsoft. It might be .net 2, and then update with the appropriate .net service packs.
    Read my blog here.
    Aug 2005
    USA
    Interesting. The author mentions the need for .NET on his website but goes on to say that the remedy is to update. I'll give it a try tonight. I'm at work now. Thanks.
    Aug 2005
    USA
    Surprisingly my .net files were out of date. I downloaded 2.0 & 3.0 and instaslled them. They were the only ones available. Unfortunately the runtime error remains. Any thoughts?
  7. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    Try opening Windows Update and see if any .Net updates/service packs are available.
    Edit: http://www.microsoft.com/net/Download.aspx also seems to have 1.1 and 3.5 available. I'd recommend seeing if Windows Update has any updates for the versions of .Net you have installed and whether or not that helps first, though. Better to not install all the available versions of .Net unless it's absolutely necessary.
    Aug 2005
    USA
    Windows Update is how I installed versions 2.0 & 3.0. As of yesterday that was the latest available, however I see what you mean at the link you furnished. I will install it and see if it helps. the only thing the author says is to keep your computer current.
    Jul 2006
    World
    Sometimes windows update needs to be run more than once as it cannot install all available updates at once as some have prerequisites. It more than likely informed you of this.
    Aug 2005
    USA
    Yes, I'm aware of this. I want back to Update and there were none available so I went direstly to the .NET page and downloaded 3.5. It didn't help.
