I have a DVD that has audio that is slightly out of synch. We're talking about 170 miliseconds here, pretty small difference but it's annoying me.
The VOB files have been ripped onto my computer and now I'm trying to find the right software to just delay the audio without re-authoring or re-encoding the entire movie so that I can burn the VOBs back to a DVDR.
I'm currently doing it the long way (putting it through TMPGEnc DVD Author) while I continue to search for the secret of quickly changing the audio delay to all the VOB files as a whole, and nothing more.
I've tried several different programs but just couldn't find a simple solution, and I'm starting to think there isn't one. If anyone could suggest a program or two or point me in the direction of a guide I'd be very relieved. And yes, I've tried searching this site and the rest of the web for this elusive simple task.
Results 1 to 10 of 10
You may be better off using a program like VOB2MPG to rip the whole DVD to a single MPG file, then demuxing the audio and applying a audio offset. You will lose menus this way, but it should be easier. This is assuming the audio sync was messed up before authoring. If each VOB has a different sync error, this could get complicated.
What format is the audio in?
And welcome to our forums.
Audio is AC3. The audio sync must have been a little off before it was made into all the VOBs. DVD Author at least lets me set the audio delay, and in turn I can make a better menu with it than what it originally had.
It's just a job I'll have to let work overnight while I'm sleeping. Thanks for the input though! -
1. Demux the problem video from the DVD (PGCDemux)
2. Remove the delay (DelayCut, or fix it when reauthoring)
3. Reauthor (Muxman, not forgetting to load the chapter points - Celltimes.txt - in File->Import Chapters)
4. Replace the fixed video back into the original using the Replace button of VobBlanker. -
What i do is use tda to extract to dvd files to mpg then use tmpg to demux the mpg and then load the m2v into virtualdubmod and convert the ac3 to wav with goldwave and insert the wav into virtualdubmod and adjust the delay after i find the right amount after playing in vdub and then save wav as.
After doing this i reauthor the m2v with the new wav and test and burn.You can use other extractors and convertors but i find using vdub the best way to align the audio to video by incremental adjusting and playing.I think,therefore i am a hamster. -
Hay um i um can fix my delay with delaycut but then how do you convert it so you can watch it cause it comes out as a file
I didn't open it as an ac3 file i opened it after puting it through Auto Gordian so it was the whole movie.
yep i did do that and it still wont work
ive even decrypted it again and again just to make sure
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
problem with video delay - different for each separate VOB
By Heliooos in forum DVD RippingReplies: 2Last Post: 28th Apr 2011, 04:03 -
.ts to .mkv audio delay problem
By AlienWare in forum Video ConversionReplies: 6Last Post: 5th Feb 2011, 14:42 -
Splitting VOB files with audio delay/quality loss?
By S0VIET in forum Authoring (DVD)Replies: 8Last Post: 30th Oct 2010, 21:48 -
VOB to H264 MKV (AVI Synth and audio delay help)
By PsyCLown in forum Video ConversionReplies: 1Last Post: 20th Feb 2009, 01:52
