hi all!
i cant play a m2ts file
(i used real alternative but nothing, same using powerdvd8!!!)
looks like i can play m2ts file with powerdvd8 that have only AC3 tracks, but not m2ts files that have DTS or TRUE-HD tracks...
the strange thing is that (if i remember well) i was able to play m2ts before and
i had installed:
-k-lite codec
-ffdshow codec
-nero 8 lite (with blu-ray activacted)
-now i have disinstalled k-lite codec (as suggested) to use ripbot
-installed nero 9 (with blu-ray activacted)
maybe i have to roll back?
or someone here can give me a hand?
maybe i need some codecs or i make some mistake...
thx!![]()
Results 1 to 13 of 13
you need powerdvd8 "ultra" version to play those audio formats. if you have the ultra version it may have been messed up with the codec pack removal. try uninstalling it and a re-install.
hi aedipuss, i have powerdvd8 ultra so maybe i have to uninstall and reinstall (i say disinstal...my english suck lol )Originally Posted by aedipuss
tyvm i'll try!
ho wellOriginally Posted by aedipuss
unistalled ffdshow
then
installed k-lite and ffdshow with default setting
now i can see the video
can play DTS files
but still CANT play TRUE-HD!
i'll try now unistalling k-lite and ffdshow
and installing ONLY ffdshow!
there are any setting i have to set while installing ffdshow or the default are fine?
help pls!
with "media player classic" now i can play m2ts files:
- i can see the video
- can play DTS files
- but still CANT play TRUE-HD! i mean the m2ts file start but no sound
with "powerdvd8 ultra" now i can play m2ts files:
- but still CANT play TRUE-HD! i mean the m2ts file DONT START and powerdvd8 freeze -
try a different vid with trueHD, maybe your test one is bad.
what you mean with:Originally Posted by aedipuss
another player or what?try a different vid
can you be more clear pls?
my english is not so good, ty!
sorry. -- vid = video -- i was suggesting for you to try a different movie with trueHD to see if it was the file you were using that was bad.
haaa ok, np, now i understand what you mean!
...but i tested 4 different movie (all have true-hd) and same result!
strange!
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 02:52 -
MPC "cannot render the file" on some .M2TS files, but not all??
By insaneoctane in forum Blu-ray RippingReplies: 2Last Post: 24th Jun 2010, 11:45 -
DVD player won't play entire "avi" file
By hifiguy in forum Newbie / General discussionsReplies: 4Last Post: 7th Jun 2010, 02:05 -
corrupted m2ts file - "cannot detect stream type"
By ac1j2 in forum Newbie / General discussionsReplies: 0Last Post: 4th Mar 2010, 08:51 -
Cant Play / Load A RAW DV file "Codec Status Undetermined" Please
By hypnoticpimp in forum Newbie / General discussionsReplies: 4Last Post: 30th Mar 2009, 15:29
