    Mar 2008
    Hello everyone,
    I'm converting with ConvertXtoDVD 3.
    Unfortunately when i convert my videos and i burn them i get a oversized image when i play it in a DVD player. Usually, there are all widescreen videos but in the tv the corners are clipped and it seems like the whole image does not fit. Here's the log, hopefully you could tell me what I'm doing wrong.
    12/17/2008 8:27:02 PM info BURN: Media removed. Burning layer not ready to write
    12/17/2008 8:26:43 PM info BURN: Finalization Time 00:00:32 - Total completion time 00:05:35
    12/17/2008 8:26:11 PM info BURN: Write finished in 00:05:03 - Finalization start here. Avg. burn rate 5.02
    12/17/2008 8:21:45 PM info BURN: Lead-in burning time (mS) 0
    12/17/2008 8:21:08 PM info BURN: Write started 935184 sectors to write
    12/17/2008 8:21:08 PM info BURN: Writing speed requested x8.0, effective x8.0
    12/17/2008 8:21:08 PM info BURN: Available write speed: 12x, 8x, 4x
    12/17/2008 8:21:08 PM info BURN: Media ID: CMC MAG-M01-00
    12/17/2008 8:21:08 PM info BURN: Media type: DVD+R
    12/17/2008 8:21:06 PM info BURN: Scanned files #7, folder #2 - total size 1914161152 b. (1.78 Gb.)
    12/17/2008 8:21:06 PM info BURN: Inserted media type : DVD+R
    12/17/2008 8:21:06 PM info BURN: Write started
    12/17/2008 8:21:01 PM info --------------Encoding end--------------
    12/17/2008 8:21:01 PM info Disc name: "I Am"
    12/17/2008 8:21:01 PM info Burned folder: "I:\Videos\IAm\"
    12/17/2008 8:20:47 PM info BURN: New media inserted. Burning layer is ready to write
    12/17/2008 8:20:45 PM info BURN: Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
    12/17/2008 8:20:45 PM info BURN: New Drive selected : 0:0:0 - HL-DT-ST DVD-RAM GSA-E60L 1.00 [H] (Usb)
    12/17/2008 8:20:45 PM info Total size 1825 Mb., Target size Custom 4300 Mb., Occupation 42.45%
    12/17/2008 8:20:45 PM info Conversion completed in 01:26:42
    12/17/2008 8:20:44 PM info Rendering rate: 1.42 x Realtime
    12/17/2008 8:20:44 PM info DVD duration (incl. menus) 02:03:20 (~ 7400 sec.) - rendering time 01:26:42
    12/17/2008 8:20:17 PM info Generated duration 7382.92 sec., expected 7383.58 sec.
    12/17/2008 8:20:17 PM info P-SDT buffer Underflow 1 times, 1260 bytes peak
    12/17/2008 8:15:59 PM info Chapter #25 start at 120:0.193
    12/17/2008 8:13:09 PM info Chapter #24 start at 115:0.143
    12/17/2008 8:10:01 PM info Chapter #23 start at 110:0.093
    12/17/2008 8:06:54 PM info Chapter #22 start at 105:0.294
    12/17/2008 8:03:49 PM info Chapter #21 start at 99:59.994
    12/17/2008 8:00:49 PM info Chapter #20 start at 95:0.077
    12/17/2008 7:57:43 PM info Chapter #19 start at 90:0.278
    12/17/2008 7:54:26 PM info Chapter #18 start at 84:59.978
    12/17/2008 7:51:27 PM info Chapter #17 start at 80:0.295
    12/17/2008 7:48:19 PM info Chapter #16 start at 75:0.245
    12/17/2008 7:45:09 PM info Chapter #15 start at 70:0.446
    12/17/2008 7:41:58 PM info Chapter #14 start at 65:0.146
    12/17/2008 7:38:52 PM info Chapter #13 start at 60:0.346
    12/17/2008 7:35:59 PM info Chapter #12 start at 55:0.180
    12/17/2008 7:32:36 PM info Chapter #11 start at 50:0.380
    12/17/2008 7:29:08 PM info Chapter #10 start at 45:0.330
    12/17/2008 7:25:33 PM info Chapter #9 start at 40:0.281
    12/17/2008 7:21:38 PM info Chapter #8 start at 34:59.981
    12/17/2008 7:17:36 PM info Chapter #7 start at 30:0.181
    12/17/2008 7:13:44 PM info Chapter #6 start at 25:0.382
    12/17/2008 7:09:17 PM info Chapter #5 start at 20:0.199
    12/17/2008 7:05:19 PM info Chapter #4 start at 15:0.399
    12/17/2008 7:01:16 PM info Chapter #3 start at 10:0.349
    12/17/2008 6:57:30 PM info Chapter #2 start at 5:0.183
    12/17/2008 6:54:05 PM info File #1 Stream #2 Sync. delay : 0.00 ms
    12/17/2008 6:54:05 PM info File #1 Stream #1 Sync. delay : 0.00 ms
    12/17/2008 6:54:05 PM info Starting at 00:00:00.000 (0 µS)
    12/17/2008 6:54:05 PM info ********** Stream delay(s) for playback position 1 **********
    12/17/2008 6:54:04 PM info Output Stream #2 (AUDIO) - Audio: ac3, 48000 Hz, 5:1, 448 kb/s
    12/17/2008 6:54:04 PM info Output Stream #1 (VIDEO) - Video: mpeg2video, yuv420p, 720x480 [PAR 32:27 DAR 16:9], q=2-31, 4283 kb/s, pulldown: 23.976 -> 29.97 Fps
    12/17/2008 6:54:04 PM info Video processing: Fast bilinear resampler (560*272)->(720*412)
    12/17/2008 6:54:04 PM info Video processing: Pad (Left:0 - Top:34 - Right:0 - Bottom:34)
    12/17/2008 6:54:04 PM info Video processing: Crop (Left:40 - Top:0 - Right:40 - Bottom:0)
    12/17/2008 6:54:04 PM info Chapter sequences require 0 b. temp space
    12/17/2008 6:54:04 PM info ****** Source file #1 END DETAILS ******
    12/17/2008 6:54:04 PM info Stream #2 (AUDIO): Audio: ac3, 48000 Hz, 5:1, 448 kb/s [RAW COPY]
    12/17/2008 6:54:04 PM info Stream #1 (VIDEO): Video: mpeg4, yuv420p, 640x272 [PAR 0:1 DAR 0:1], 23.98 FPS
    12/17/2008 6:54:04 PM info Type: Audio/Video file with 2 stream(s) - Playback order:1 - Queue:0
    12/17/2008 6:54:04 PM info I:\Videos\IAm.avi
    12/17/2008 6:54:04 PM info ******** Source file #1 DETAILS ********
    12/17/2008 6:54:04 PM info Video bitrate 0/4283/9352 Kbps (min/avg/max)
    12/17/2008 6:54:04 PM info Resolution, TV standard, Aspect ratio: FULL D1 [720*480], ntsc, 16:9
    12/17/2008 6:54:04 PM info ----------------Title #1----------------
    12/17/2008 6:54:03 PM info Video bitrate has been set to maximum possible value for DVD specifications. Target size may not be reached.
    12/17/2008 6:54:03 PM info 2 Stream(s) found - est. duration 02:03:03.585, reference 02:03:03.585
    12/17/2008 6:54:03 PM info Opening file "I:\Videos\IAm.avi"
    12/17/2008 6:54:02 PM info Project size 4.2 Gb. (401 Mb. audio - 3.79 Gb. video)
    12/17/2008 6:54:02 PM info [ ] Don't fix audio gaps
    12/17/2008 6:54:02 PM info [ ] Engine Log
    12/17/2008 6:54:02 PM info Encoder quality: 50%
    12/17/2008 6:54:02 PM info --------------Encoding begin--------------
    12/17/2008 6:54:02 PM info --------------Menu settings end--------------
    12/17/2008 6:54:02 PM info [X] Skip root menu
    12/17/2008 6:54:02 PM info [ ] Play videos one after the other
    12/17/2008 6:54:02 PM info [ ] Loop playback
    12/17/2008 6:54:02 PM info [X] Play video automatically (skip menu)
    12/17/2008 6:54:01 PM info Template: Minimal, the most simple menu, contains 1 page(s), 3 customizable element(s)
    12/17/2008 6:54:01 PM info --------------Menu settings begin--------------
    12/17/2008 6:54:01 PM info --------------Burn settings end--------------
    12/17/2008 6:54:01 PM info Default speed selected: 8x
    12/17/2008 6:54:01 PM info BURN: Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
    12/17/2008 6:54:01 PM info BURN: New Drive selected : 0:0:0 - HL-DT-ST DVD-RAM GSA-E60L 1.00 [H] (Usb)
    12/17/2008 6:54:01 PM info [ ] Delete files after burn complete
    12/17/2008 6:54:01 PM info [X] Don't eject after burn complete
    12/17/2008 6:54:01 PM info SAO setting: Automatic
    12/17/2008 6:54:01 PM info [ ] Include originals
    12/17/2008 6:54:01 PM info [X] Burn result to DVD
    12/17/2008 6:54:01 PM info --------------Burn settings begin--------------
    12/17/2008 6:46:52 PM info 25 Menu templates loaded.
    12/17/2008 6:46:44 PM info BURN: Using Patin-Couffin driver Version 1.37, Internal revision 37 - Async. Access mode
    12/17/2008 6:46:40 PM info Tuning Performances for AMD Athlon(tm) XP 2400+ with 1 core(s) CPU
    12/17/2008 6:46:38 PM info User default language : 1033 (0x0409h) - English (United States)
    12/17/2008 6:46:38 PM info System default language : 1033 (0x0409h) - English (United States)
    12/17/2008 6:46:38 PM info Version 2.99.9.500
    12/17/2008 6:46:38 PM info ExeName : "C:\Program Files\VSO\ConvertX\3\ConvertXtoDvd.exe"
    12/17/2008 6:46:38 PM info OS : Microsoft Windows XP Personal Service Pack 2 (Build 2600)
    12/17/2008 6:46:31 PM info ******************** Report session started ********************
  2. Member MysticE's Avatar
    Nov 2003
    Originally Posted by jagabo
    Overscan
    Might be more to it than that with CXD3. Early versions had a 'Recommended' default setting that would enlarge sources to better fill a WS TV.
    Go in to CXD, Video processing, and choose 'Letterbox' and see if that fixes things. In the latest version, Letterbox is now 'recommended'.
    Mar 2008
    I found the solution to my problem.
    In 'options', 'TV Format' tab, under 'TV Screen', click the drop down menu and select '16:9 Widescreen'.
    I also have selected the 'letterbox' option.
    Thanx guys for your help!
