When I play a video (.vob) in VLC, every time I get to a chapter break, the movie glitches.
What can be done to fix this?
Thank you,
Chris.
Results 1 to 14 of 14
OK, on this movie, there is 6 IFO files. Which of these is "the IFO file"?
DVD File/Folder Structure
Explanation:
. BUP = Backup files of the IFO files.
. IFO = The IFO files includes information such as chapters, subtitle tracks and audio tracks.
. VOB = The VOB files contains the actual video,audio,subtitles and menus.
Folder Files Explanation
AUDIO_TS (undefined) DVD Audio
VIDEO_TS VIDEO_TS.BUP
VIDEO_TS.IFO
The first video play item, IFO, usally a copyright notice or a menu
VIDEO_TS.VOB The first video play item, VOB
VTS_01_0.BUP
VTS_01_0.IFO Title Set 01, IFO, usually the main movie
VTS_01_0.VOB Title Set 01, VOB 0, the menu for this title
VTS_01_1.VOB Title Set 01, VOB 1, the video for this title
VTS_01_2.VOB Title Set 01, VOB 2, if larger than 1 GB it will be splitted into several vobs
VTS_01_3.VOB Title Set 01, VOB 3
VTS_01_4.VOB Title Set 01, VOB 4, up to 10(0-9) VOB files if necassary
VTS_02_0.BUP
VTS_02_0.IFO Title Set 02, IFO, usually movie extras
VTS_02_0.VOB Title Set 02, VOB 0, the menu for this title
VTS_02_1.VOB Title Set 02, VOB 1, the video for this title
VTS_xx_x.BUP
VTS_xx_x.IFO And so on
VTS_xx_x.VOB
VTS_xx_x.VOB
VTS_99_9.VOB Up to 99(1-99) titles with max 10(0-9) VOB files eachPull! Bang! Darn! -
OK, thank you. Still don't know how to play these files in VLC without glitches.
Instead of watching a DVD in the DVD/RW Drive, I want to put it on the HD and watch it from there.
I open VLC, open the folder. I Ctrl + A, highlight everything, play. The movie plays but has glitches at each chapter.
How are you supposed to play a movie?
Thank you for replies,
Chris. -
You should only have to open this file : VIDEO_TS.IFO and take it from there.
Personally have not seen this behaviour from VLC, although the very latest version is doing some funky things.
You might also try The KM Player, or Media Player Classic Home Cinema. If you still get the same problem then you either have a system problem, or the disc was not ripped properly.
Which does lead to the question - how did you rip it ?Read my blog here.
VLC has always done this for years, with different versions, and all discs. I ripped this time with DVDFab HD Decrypter. video_ts.ifo lasts for about 1 second, then ends. Nothing on the screen, just the slider goes for a second then stops.
Chris. -
Just tried it in Realalternative (MPC). The video_ts.ifo plays good.
I was using VLC because it was so highly recommended on the forums. Doesn't even work right. Never has for me.
Thanks for the suggestions, I forgot I had media player classic.
Chris. -
Pretty good guns1inger, it works now.
Thank you to jagabo for helping me get to it. Thank you to all the helpers.
Chris. -
Which output driver did you end up using? And which wasn't working originally?
Can't remember what one I was using. However it came was the one tho.
What worked was, "Default". I read more and it was suggested for better quality to use VMR 9 (renderless). That worked also.
Thank you for asking. It's good for others who read this in the future. Its always good to post back for the benefit of others. Thanks for the reminder.
Chris.
VLC Video Player won't open subtitles
By snafubaby in forum Software PlayingReplies: 2Last Post: 14th May 2011, 22:47 -
Stuttering video with VLC Player on the extended screen (TV)
By timebandit in forum Software PlayingReplies: 0Last Post: 28th Nov 2009, 11:11 -
VLC media player lagging video
By Obamargarine in forum Software PlayingReplies: 4Last Post: 19th May 2009, 21:36 -
when i try to play a video in vlc player it starts to lag
By icedemon in forum Software PlayingReplies: 4Last Post: 17th Aug 2008, 20:33 -
No video, only audio VLC Player
By indiannawaf in forum Newbie / General discussionsReplies: 2Last Post: 15th Aug 2007, 06:26
