My brother has a Acer Aspire 5312 where the screen does not light up does anyone know how to fix this? When I plug it to my monitor the laptop plays but the screen does not come on with or without it connected to a monotor.
Go to Control Panel>Power Options and make sure the monitor doesn't turn off.If that doesn't help the backlight is burned out,time for a new laptop.
The Inverter Board that powers the Backlight is shorted. This is a very common problem with LCD monitors. If you are handy with electronics, then this is a fairly easy item to replace, and the Inverter is fairly cheap when you buy the correct 1 for your laptop in eBay. I recently replaced 2 of these on some laptops that I picked up very cheap because of the same problem.
"I will not be pushed, filed, stamped, indexed, briefed, debriefed, or numbered! My life is my own" - the Prisoner
(NO MAN IS JUST A NUMBER)
be seeing you ( RIP Patrick McGoohan ) -
How do you replace the inverter and does it involve soldering? Also if i shine a flashlight into the monitor i can kinda see thing but it is very dark.
The Inverter is inside the display unit and usually has 2 plug in connectors - 1 for the lamp and 1 for the power - no soldering.
You really must be handy with taking apart and repairing electronics, otherwise you will damage the unit.
I would like to think that I am kinda handy with electronics I have taken apart my ps2 and fixed it and a few desktops I fixed and built a few.
OK - then you should be able to do this. Basically, you have to get inside the screen assembly - usually a few screws to open it up, but you may have to take it off the laptop to separate the front bezel. it may be accessible then, but it also could be mounted behind the LCD.
Mpeg-4 stutter freeze on laptop 1, laptop 2 plays fine- why?
By sevenofone in forum Software PlayingReplies: 1Last Post: 8th Apr 2011, 16:15 -
Help laptop to tv
By celecon in forum Newbie / General discussionsReplies: 6Last Post: 29th Jan 2009, 14:53 -
Formatting laptop, how do i know if a laptop has wifi capabilities?
By ricardouk in forum ComputerReplies: 8Last Post: 21st Nov 2008, 09:24 -
DVDs work in desktop PC but not in laptop - previously worked in laptop
By Brent Jewell in forum Newbie / General discussionsReplies: 3Last Post: 6th Nov 2008, 19:40 -
using second laptop as a video in from laptop with broken display
By joycefitz in forum Newbie / General discussionsReplies: 4Last Post: 18th May 2008, 23:56
