I want to upgrade my xp 3000+ for play mkv h264 1080p files.
I read that atom 330 can play 1080p h264 someone can confirm it?
Otherwise i will buy a core 2!!
Thanks!
				Results 1 to 13 of 13
	thanks for answer, maybe quad core it's exagerate!! i think it's enough a core 2 duo!!!!!
	Any current single core CPU is sufficient if you have a graphics card that supports hardware decoding. Otherwise, any dual core C2D or A64 X2 is sufficient for software based decoding.
 I'm not sure about the Atom 330. The 945 graphics probably does't have hardware h.265 and VC-1 decoding. But the dual core CPU should be able to handle it.
 Guess not. Atom is usually paired with Intel Extremely Poor Graphics:
 http://www.youtube.com/watch?v=y6QXaNTgT68
 And from the guys blog:
 http://ig33ku.blogspot.com/
 But it may depend on what decoders he is using (whether the decoder is single or multi threaded).Can watch full 720p vids. Stutters on 1080p vids.
	interesting!
 if i buy a atom 330 with a video card that supports hardware decoding i'm able to watch all h264 encoded file?
	want a really cheap upgrade that can definitely handle 1080p (i know because my other computer is the exact same thing)?Originally Posted by Xeo84
 http://www.newegg.com/Product/Product.aspx?Item=N82E16819103211
 http://www.newegg.com/Product/Product.aspx?Item=N82E16813131095
 http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.147936
 http://www.newegg.com/Product/Product.aspx?Item=N82E16814141079
 and buy some ram, 2 gigs of ddr2 800 will cost you about $50, so there you have it, for a touch over $200 you can build a nice little computer that can handle any everyday task, including gaming at reasonable resolutions and some light video editing/transcoding.
 the nice thing about the above setup is that you can go to a quad core phenom with little problem if you so choose (i also have a similar setup with an ati video card and a phenom 9500) for a few bucks more.
 or you could wait just a bit until amd releases their new dual core x2's (based on the current phenoms, supposed to be a good match performance wise with core 2's) or if you have the dough wait another month for the phenom 2, which is supposed to be able to give the new core i7's a run for the money.
 but even if you're on a tight budget, for $200 the above listed pc is not bad at all, and like i said i have the exact same setup and it can play any 1080P movie i have thrown at it.
	An Atom makes no sense, because even AMD have CnQ tech inside. *** Now that you have read me, do some other things. ***
	I'm a little late to this party, but you still need somewhat of a decent CPU for the decryption of the video...and the atom falls below this classification  . .
  asus pundit p1 ph1 bareboneBy mrbond in forum Media Center PC / MediaCentersReplies: 4Last Post: 11th Dec 2013, 04:06
  Shrinking 1080p MKV, change to 720p or keep as 1080p?By Phat J in forum Video ConversionReplies: 5Last Post: 28th Nov 2010, 10:35
  XBOX 360 HD DVD drive on Asrock ION 330 - 1080p playbackBy dhomas in forum Software PlayingReplies: 2Last Post: 3rd Jan 2010, 22:20
  1080P Playback On My PC? And WD 1080p Player Need A Expert!By wpittsen in forum Newbie / General discussionsReplies: 2Last Post: 30th Sep 2009, 13:43
  Invalid Public AtomBy Michael Boutros in forum ffmpegX general discussionReplies: 3Last Post: 22nd Apr 2009, 13:26
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			![[_chef_]'s Avatar](customavatars/avatar30571_1.gif)
