I'm looking for a effect that I can add to a video I'm working on that simulates an old film projector that's starting up. I would like to add this effect to the start of the video and it would only last a second or two. Sorry, I'm not sure the exact terminology of this.
Also, I would like to find some type of sound effect application that would allow me to add sounds to the video. Actually, just generate the sounds and I'd then add them in in after effects.
I'm using a new Mac Pro dual quad but also have a few wintel boxes running xp pro and xp pro x64.
Thank you in advance,
Joe
You add sounds in your editor (or I guess After Effects, although that isn't ideal). Sound Effects generators are for creating unreal noises or test tones. If you want real effects you have to record them or download recorded effects. There are plenty of free libraries around if you google. Use and audio editor to combine or edit the sounds before.
Read my blog here.
Thanks again guys!
Is there a plug-in for after effects that simulates an old projector starting up - the odd flicker that occurs?
How to use video projector as Party Laser Show.
By SingSing in forum Newbie / General discussionsReplies: 0Last Post: 18th Oct 2011, 13:35 -
Video from light projector?
By Compo in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 15th Jun 2011, 19:51 -
Need help with deflickering of video of projector screen
By SCDVD in forum EditingReplies: 6Last Post: 31st May 2010, 15:09 -
Video delay to projector
By Hutch81 in forum Newbie / General discussionsReplies: 1Last Post: 6th May 2009, 12:59 -
Basic video projector question
By jbaugh in forum Newbie / General discussionsReplies: 10Last Post: 14th Apr 2009, 01:58
