I'm not sure how to remove this Baidubar virus, I tried AVG, Spybot and Adaware but didn't work. Anything FREE that can remove this?
Results 1 to 22 of 22
download hijackthis
Believing yourself to be secure only takes one cracker to dispel your belief. -
GKar,
The spywareremove is NOT FREE. IS the only way to remove the baidu bar with that? Malewarebytes did not find anything either. -
are you using internet explorer 7? if so, go to tools and manage add-ons and enable or disable add-ons and look for it there. If you find it you should be able to select it and delete it.
http://www.oral8.cn/viruscom/viruscom_16243.htmlOriginally Posted by jyeh74
I am using IE6. There is a way to remove, but it is still hidden in the computer and is showing up
Hello jyeh74;
Eset shows that virus in their database, so I assume this
http://www.eset.eu/eos/eset-online-scanner
will be effective. No guarantees of course.
It's free and easy to use. Give it a try.
This is most probably a self-replicating virus, so you need to first;
-download/update the Eset scanner/scan and quarantine anything detected as malware.
-Then-
-turn off system restore.
-Then-
-reboot into the safe mode.
-Then-
-run the Eset scanner again.
If the virus (or any other malware) is found, quarantine it.
-Then-
-reboot into the normal operating mode, turn system restore back on, run a third scan to assure that the virus did not replicate.
If your computer checks clean following the third scan, reboot again to normal mode.
System restore should have a new restore point and your computer should be clean.
If the Eset scanner fails to detect or remove the virus, try A-Squared free and use the deep scan mode following database update. Again, best results will be obtained scanning in safe mode with system restore disabled.
Good luck !THREADKILLER !
References on File. -
... or you can download ESET NOD32, one of the best anti-virus sofware, and have it as a trial for 30 days for FREE. Fully functional during that trial period.
http://www.eset.eu/download/trial -
who has actually used these FREE trial sw to remove the baidu bar and had success?
baidu has been around for years and isn't a hard to remove one. follow the steps on this page and remove it yourself.
http://www.spywareremove.com/removeAdwareBaidu.html--
ESET NOD32 Antivirus 3.0 or ESET NOD32 Antivirus ??Originally Posted by Jeremiah58
my vote goes to NOD32Originally Posted by jyeh74
whatever the 30 day demo is(3.0 is the latest ).just be sure to turn system restore off before you scan.
http://www.eset.com/download/free_trial_download.php -
Here are download links for the avtivirus and security suite.
These are for version 3.
There is a version 4, but it is in beta.THREADKILLER !
http://www.winxpfix.com/HT-Turn-Off-Windows-XP-System-Restore-to-Save-Space.htm
be sure you have ONLY one AV on your pc -
Right click on "My Computer"
"Properties"
"System Restore"
Tick "Turn Off System Restore"
Reboot.THREADKILLER !
This one: ESET NOD32 3.0 Antivirus for Win XP/2000/Vista (32-bit)Originally Posted by jyeh74
Please be sure to uninstall any other antivirus software, before you start the installation of NOD32.
Boot into safe mode and install it. Let it download an update.
Boot into safe mode again, start NOD32 and after that click on NOD32 button and click on "In-depth analysis". It should get you rid off of all malicious software you got on your machine.
You will have a fully functional NOD32 for a trial period of 30 days.
I recommend it and suggest that you consider to buy it after that period.
Question about virus so terrible that Ghost restore did not kill the virus
By jimdagys in forum ComputerReplies: 24Last Post: 27th Apr 2010, 10:58 -
A virus or not?
By romanstopme in forum ComputerReplies: 11Last Post: 2nd Feb 2010, 15:07 -
Virus or something else?
By alintatoc in forum ComputerReplies: 12Last Post: 1st Oct 2009, 02:57 -
VIRUS,VIRUS, Getting blocked accessing antivirus sites
By G)-(OST in forum ComputerReplies: 11Last Post: 10th Apr 2009, 02:40 -
virus or something else
By alintatoc in forum ComputerReplies: 3Last Post: 2nd Mar 2009, 14:37
