Hiya,
I'm new to all this Video stuff so any help would be much appreciated! I have a problem where QT-7 and MPEG Streamclip will not play the video of an AVI file, it plays the audio but not the video there is just a blank screen.![]()
Here's what I've done so far; PS3 plugged into EasyCap - AMCap 9.02 records to an AVI file - AVI file plays in WMP, WMM and Nero 3 but not QT or MPEG Streamclip. When I open the file in Avidemux it plays and under file/properties it says "codec 4CC YUY2. I assume that I do not have the right codec in QT to play the video but am unsure.
Please Help!!!
QT, along with its "gang", is picky. I have never figured it out. As well, it seems to live off hacks to be worth using.
Does it ask you to download additional software? Is so, then do so. If not, then forget it and use VLC instead.
I do try and keep QT compatibility, particularly whenever I need to encode something to H.264 and want a sense of "universal-ness" to it, but still will never use QT to actually play the file.
And you're better off installing ffdshow, or even the DivX/Xvid codec (particularly since they render YU12 very fast) instead for most AVI playback.I hate VHS. I always did. -
Can I use ffdshow or DivX/Xvid in QT and MPEG Streamclip, or is there a free codec that I can download and use in QT-7/MPEG Streamclip that will read YUY2?
MPEG Streamclip MPEG-TS to MPEG4/H264 (file size & aspect ratio query)
By Heathy65 in forum Video ConversionReplies: 5Last Post: 4th Apr 2012, 12:31 -
No audio when saving .MPEG file from VOB stream using MPEG Streamclip?
By Bix in forum MacReplies: 3Last Post: 25th Jul 2010, 18:12 -
How to convert an MPEG file to DV-AVI Type 2 using MPEG Streamclip
By MAdNEZ in forum Newbie / General discussionsReplies: 15Last Post: 4th Aug 2009, 08:30 -
MPEG Streamclip, "Headed MPEG"s & the mystery of the missing
By daffo2 in forum MacReplies: 5Last Post: 15th Jun 2009, 05:27 -
Mpeg Streamclip and Final Cut Pro .mpeg...Only 1 hour clips?
By checksum in forum MacReplies: 10Last Post: 17th Dec 2008, 00:38
