Hello!
Basically, I'm trying to record from my xbox360 straight to dvd using a dvd recorder . The problem is that the signal going into the dvd recorder is NTSC (actually my 360 calls it PAL-60... maybe that's not proper ntsc). When the dvd player is in pal mode, I get mostly black and white with random, contained splashes of colour. And when in ntsc mode it is a horrible shade of green.
Following some advice in another thread (on a slightly different subject) I have switched display modes before inserting my blank dvd (so that it is formatted in either pal or ntsc). This didn't work, even when switching back to pal to re-watch after recording.
The most puzzling thing about this is that when the dvd recorder is in stand-by mode, the signal still goes through the machine, out into my tv and comes out in beautiful, full colour. Then, as soon as I switch the recorder on, it reverts to horribleness.
I'm assuming (hoping), because of that last point, that there is some way to get around this without having to buy extra equipment.
Any and all help would be hugely appreciated.
Oh yeah, forgot to say, I'm currently without a capture card and I read that even if I had one it's unlikely it would support PAL-60. I have captured lots of stuff from my 360 in the past (via dvd) but that was always in PAL-50.
Pal-60 is something of a combination of NTSC and PAL. It's hard to find a device that will capture that properly.
it's possible my dvd recorder just won't do it then? Any idea why it displays fine when in stand-by mode?
thanks for the quick reply
In standby mode it simply passes through whatever is sent ot it. It doesn't really look to carefully at it.
I know some pioneers can record PAL-60, but you have to dig around in the menus and tell it what the source is going to be before recording.Read my blog here.
cool, thanks for the help anyway
I'm going to have to get myself a good capture card instead. -
yeah, I've heard about this, thanks for the heads up.
I see loads of youtube vids saying 'how to capture pal-60 on any capture card' etc. What's the deal with this?
EDIT: I don't mean 'explain in detail how to do it' lol. I just mean, is it something that works?
how do you record xbox 360 gameplay while using microsofts xbox 360 vga ?
By rushinplaya in forum Capturing and VCRReplies: 18Last Post: 3rd Apr 2010, 06:19 -
Help encoding 360 x 360 videos (spherical movies)
By sapojow in forum Video Streaming DownloadingReplies: 29Last Post: 1st Aug 2009, 19:23 -
Using the XBOX 360 HD DVD player on a PC
By the_importer in forum Media Center PC / MediaCentersReplies: 4Last Post: 12th Nov 2007, 20:39 -
Can you interchange a xbox 360 hddvd drive between pc and 360?
By yoda313 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 23rd Oct 2007, 09:06 -
xbox 360 hd dvd addon
By tk69045 in forum Media Center PC / MediaCentersReplies: 0Last Post: 31st Jul 2007, 13:59
