I have a question about this process, with this program. it says, in the cmd window that it extracts HD core from thd.
so what i want to know is the conversion then just happening between the embedded ac3-640 stream of the thd file and the remaing dts, or does some of that HD info get converted into dts as well??
ie: is this a pointless conversion compared to downconverting to ac3-640 while demuxing and leaving it at that; because i believe if i'm just converting ac3-640 to dts, all i'm getting is a file twice the size, but with same sound, due to source. is that correct??
Results 1 to 1 of 1
eac3to: DTS-HD MA (Arcsoft) -> W64, clipped the center channel
By Asterra in forum AudioReplies: 1Last Post: 19th Apr 2012, 02:37 -
eac3to: error converting 6.1 ch DTS -> AC3
By KushSmoka420 in forum AudioReplies: 5Last Post: 6th Mar 2012, 11:35 -
eac3to with HdBr Stream Extractor Decoding DTS-HDMA?
By MACCA350 in forum Blu-ray RippingReplies: 8Last Post: 17th Aug 2011, 01:01 -
THD to AAC Failing in MeGUI
By ATi Guy in forum Newbie / General discussionsReplies: 0Last Post: 25th Feb 2011, 05:51 -
MKV video with AC3-THD audio
By zenzen1 in forum AudioReplies: 6Last Post: 26th May 2010, 22:21
