    Dec 2008
    PLEASE can you help with the folllowing message, if i convert a avi 2 dvd with out a menu it works fine, but when i do the same disk with a menu i get the following error right at the end of the progress
    Version: SVCD2DVD 2.5
    Build: 2.5.5010.0
    Type: System.ComponentModel.Win32Exception
    Source: System
    Message: The application has failed to start because its side-by-side configuration is incorrect. Please see the application event log for more detail
    InnerException:
    StackTrace: at System.Diagnostics.Process.StartWithCreateProcess( ProcessStartInfo startInfo)
    at System.Diagnostics.Process.Start()
    at x3284ccece41ee22b.xc5b4b7804027a156.x160a0bf4de8f6 bd0(String xd168ac2ed64c4662, String xa6a477a49a1a2599, String x450f47a9028f884b, xa0efedb9fec1e88f x8b49c96cd0348808, Boolean x74effd3a0f44569e)
    at x3284ccece41ee22b.xddb8d1ea6c9958c7.x8291881ef07bb 5c7(Boolean x7ce1fdb24a74c398)
    at x3284ccece41ee22b.xd3764d4f1e921081.x4f3432523597d cf6(Boolean x7ce1fdb24a74c398)
    at x3284ccece41ee22b.xd3764d4f1e921081.x2e6504f39decc 498()
    at x3284ccece41ee22b.xd3764d4f1e921081.xf81783e1b359f fc3()
    at System.Threading.ThreadHelper.ThreadStart_Context( Object state)
    at System.Threading.ExecutionContext.Run(ExecutionCon text executionContext, ContextCallback callback, Object state)
    at System.Threading.ThreadHelper.ThreadStart()
    could you please advise as i never had this b4 on previous versions
    cheers stitch
  2. Can you post your log file?
    Dwight
    "A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
    - Herm Albright
    www.martialconcepts.com
  3. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    This should be fixed in Version 2.5.5020
    Dec 2008
    sorry 4 the late responce, just downloaded 2.5.5020 and run the same project again and all worked fine...very happy chappie
    thanx 4 your help
    stitch
  5. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
