I'm using Xilsoft DVD Ripper to convert some footage to AVI, but even with the video quality settings set to highest, the AVI quality is much worse. Is there better programs out there for DVD to AVI or possibly to MP4? What do you guys use?
Bringing your photos and memories to life
www.YourHighlightFilm.com -
I use
To AVI DivX/Xvid
AutoGK or Fairuse Wizard
To mp4 h264
Fairuse Wizard or Xvid4psp or Ripbot264 or Handbrake
and if the output file size is does not matter then use Constant Quality encoding mode in those tools(also called constant quantizer encoding) or else use 2-pass encoding and set the file size. -
Thanks a lot Baldrick, I'll give those two a try and post my results later,
Thanks again!Bringing your photos and memories to life
"Without quality loss.." pretty much means you're going to have quite large files. One problem you might have is that some devices require files to be smaller than 2gb (Fat32) also the bitrate might be too high for some devices.
I use the same progs as above, but dont do any h264 (yet).Corned beef is now made to a higher standard than at any time in history.
The size of the files doesn't matter in my case. I'm taking these large files and maybe only using 10 to 15 short (3-10 seconds) clips for a sports highlight film. But I would like these clips to be as good quality as they are on DVD.
I'm trying the AutoGK right now. . . . .Bringing your photos and memories to life
HUH?Originally Posted by jorgecmn
I tried AutoGK with the target quality set to 100 percent. The finalized avi was just barely better then what Xilixoft produced but still not up to par, and it took almost 3 hours to render on a AMD x2 6400 pc. I'm trying the FairUse now. . .
Is MP4 typically better quality then AVI?Bringing your photos and memories to life
MKV to AVI without quality loss - for watching on DVD player
By mr-scarface in forum Video ConversionReplies: 19Last Post: 17th Apr 2013, 17:59 -
Multiple AVI files to multiple DVD discs, no quality loss, chapter per avi
By Delta007bhd in forum Video ConversionReplies: 11Last Post: 14th Apr 2010, 09:27 -
loss of quality using convertxtodvd, AVI to DVD format
By savvy272 in forum Video ConversionReplies: 4Last Post: 6th Feb 2009, 12:03 -
how many avi/xvid to dvd before quality loss?
By wingfan in forum Video ConversionReplies: 10Last Post: 14th Jan 2009, 15:38 -
Would there be quality loss if 2 avi files of 700 mb made into one DVD
By meurglys0 in forum Authoring (DVD)Replies: 8Last Post: 11th Apr 2008, 21:57
