Hi ALL new to this forum !
Just bought a cheap HD Cam which takes mov files in this format
General
Complete name : E:\@_MP4P~1\FILE_1~1.MOV
Format : MPEG-4
Format profile : QuickTime
Codec ID : qt
File size : 6.13 MiB
Duration : 12s 145ms
Overall bit rate : 4232 Kbps
Encoded date : UTC 2008-01-22 01:02:55
Tagged date : UTC 2008-01-22 01:02:55
AMBA :
Video
Format : AVC
Format profile : Main@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : avc1
Bit rate mode : Variable
Width : 1280 pixels
Height : 720 pixels
Display aspect ratio : 16/9
Frame rate mode : Constant
Frame rate : 29.970 fps
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.000
Stream size : 5.92 MiB (97%)
Title : Ambarella AVC / Ambarella AVC
Audio
Format : AAC
Format version : Version 4
Format profile : LC
Format settings, SBR : No
Codec ID : 40
Duration : 11s 989ms
Bit rate mode : Constant
Bit rate : 128 Kbps
Channel(s) : 2 channels
Channel positions : L R
Sampling rate : 48.0 KHz
Resolution : 16 bits
Stream size : 188 KiB (3%)
Title : Ambarella AAC / Ambarella AAC
would like a pgm thats incodes to this format any help Pls & thk
I`m RIGHT the World is WRONG
You can try Quicktime pro or Mpeg streamClip(free). Choose avc/h264 video and aac audio.
And this is not latest news....moving you to our newbie forum section.
help -No sound when converting .mov files
By bloke666 in forum ffmpegX general discussionReplies: 0Last Post: 11th Dec 2011, 11:48 -
Converting or Joining MOV files
By theWallflower in forum Video ConversionReplies: 3Last Post: 8th Apr 2010, 07:00 -
Batch Converting MOV Files
By thomasj in forum LinuxReplies: 3Last Post: 25th Dec 2009, 14:50 -
converting .mov files to something I can use
By weazel_k in forum Authoring (DVD)Replies: 2Last Post: 1st Sep 2007, 16:46 -
Converting layered WMV files to MOV
By whoisquilty in forum MacReplies: 3Last Post: 19th May 2007, 13:18
