I have a 720p (1280x720) video that I shot and I want to burn it to DVD for viewing on a standalone DVD player.
I understand the DVD spec requires a stored aspect ratio of 720x480 (1:1.5). Since my video is 16:9 can I simply resize it to 720x480 (it looks tall/skinny in VDub), flag it as 16:9 in CCE and be done? Will it look correct on both widescreen and standard NTSC sets?
Thanks!
Yes it will.I resize 1280x720 to 720x480 when i encode to 16:9 but i save the original file for when i get my blu-ray player and burner.
Frame rate is also an issue. If shot 29.97 fps progressive, you would encode to 480i (wide) spec with both fields from the same frame. If you shot 23.976 fps progressive, you would encode 480p (wide) for DVD or telecine (apply pulldown) to 480i wide.
http://www.kiva.org/about -
DVD players want it to look like 480i/29.97 or 480p/23.976. You can encode the former from 29.97p source. Both fields are read from the same frame. 30p looks a bit jerky to me but most others don't seem to mind. Broadcast 720p uses 59.94 fps for smoother motion.Originally Posted by binisterRecommends: Kiva.org - Loans that change lives.
DVD > iPod Classic > TV - Aspect Ratio question
By Will Hay in forum Newbie / General discussionsReplies: 0Last Post: 18th Mar 2012, 05:05 -
Aspect Ratio Question
By rede96 in forum Newbie / General discussionsReplies: 5Last Post: 14th Aug 2011, 05:17 -
By kelticvixen in forum Newbie / General discussionsReplies: 3Last Post: 12th Jan 2009, 14:27 -
aspect ratio question
By brianhj in forum Video ConversionReplies: 6Last Post: 16th Aug 2008, 13:54 -
Aspect Ratio Question (Sorry!)
By rede in forum Newbie / General discussionsReplies: 12Last Post: 30th Dec 2007, 08:25
