I'm looking at both camcorders. If you've seen my other thread, then you knwo I want to use this for low light situations, and I really want 60 fps or higher. Any glaring issues I should know of?
Add the Canon HG20 into the mix. It's a nice camcorder and is in the same price point as well. The popularity of the Canons means accessories (batteries, wide angle lenses, etc) will be easy to find.
Since you want to record several hours of night skiing, you'll want at least 1 extra battery with a cigarette lighter charger. -
Hows Image stabilizers on these & wind noise reduction? I'm checking out the Canon, but I'm missing where the FPS is located. Any know its Fps?
The Canon can shoot at 60 fields per second, which translates into pretty good looking slow motion footage if you choose to process it that way in post.
Video shot on the ski slopes with a Canon. Not slow motion, but you'll have an idea about the look of the image and how it deals with shakiness. http://www.vimeo.com/2202158
This footage is shot with the $10,000 RED Camera at 120 frames per second. This is some of the best looking slow-mo footage I've seen.
http://vimeo.com/1340684 -
Not a fair comparison.
Someday a Red consumer model will emerge.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
So HG20 is recommended over my other choices? (BTW this looks to fit my needs, for what I will be doing)
sony hdr-sr10 to blu ray quality help
By mrdinh in forum MacReplies: 4Last Post: 16th Jun 2009, 04:31 -
Sony HanyCam HDR SR10
By guywhatever in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 27th May 2009, 20:03 -
JVC GZ-HD7, Canon Vixia HG-21 or sony hdr-sr12?
By frankie66 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 25th Nov 2008, 03:08 -
Help with JVC everio GZ-MG145
By jvcrules in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 2nd May 2008, 04:55 -
Help with my JVC Everio?
By LITEONDVD in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 18th Aug 2007, 23:31
