My subs getting smaller from left to right.
Example:
http://dasmonzta.da.funpic.de/misc/Bild2.jpg
How can I fix this?
Otherwise how/where to reset options?
I got a bunch of keys in gabest in the registry, but I don't see something what could solve this problem.
Thx for any ideas,
Monzta
I believe, i already tried all GUI options from MPC. (Hopefully I'm wrong here).
At least i definitley already have:
Set Angle Z to 0. Scale X and Y to 100.
And I supose those 3 options aren't capable to create the effect
As font i have Arial.
I also can't imagine that this is done by a font. -
I used both VMR7 and VMR9. Both with the same result. I deactivated the 3d rotation.
My MPCHC still works fine. There all subs are shown without this problem. The issue just occures with MPC.
I don't use/have Haali.
I would like to reset all options from MPC to solve this problem.... but I'm not quite sure where to do this. Somewhere on my harddisc must be a sort of place where the config is saved. And, thus, a deletion of this config should fix my problem. I guess all this is stored in the regedit, since i found no config-file. Therefore, perhaps somebody can tell me what are the directory or the entries of MPC within the regedit. -
Ok it's fixed now. I just followed my own plan and deleted the whole registry directory "gabest" and then everything was default again. After switching to VMR9 from default, the subtitles where normal again.
Unable to get Media Player classic to load subtitles.
By amax in forum SubtitleReplies: 6Last Post: 20th Oct 2009, 11:08 -
Media player classic - loading subtitles
By jujuandhuhu in forum Software PlayingReplies: 5Last Post: 19th Dec 2008, 10:26 -
ffdshow, media player classic, subtitles
By rkovideo in forum Software PlayingReplies: 10Last Post: 8th Jan 2008, 23:12 -
subtitles not showing up on media player classic
By cdcmoon in forum SubtitleReplies: 1Last Post: 1st Nov 2007, 04:06 -
Media Player Classic + SRT Subtitles
By Basketbits in forum SubtitleReplies: 3Last Post: 17th Jul 2007, 04:53
