When I save out to mpeg2 from sony vegas I get horizontal lines. Not to bad but if I could get rid then picture would be perfect.
Anny wise members know ?
peace
“He who makes a beast of himself gets rid of the pain of being a man.”
I have used the b & w filter on the footage and saved to mpeg2.
Do you see the prob?
“He who makes a beast of himself gets rid of the pain of being a man.” -
That looks like interlacing artifacts. Notice that the horizontal lines only seem to appear on moving objects. If you play it back on a TV, it should look normal. Or try using a software player that can properly display interlaced material, such as VLC or MPC and choose a deinterlacing filter. Interlaced video would be the normal format for TV, if that's what your final display is going to be.
its gonna be played back through a mac monitor unfortunately.
It will be playing through DVD software on a mac. Not sure which player it is. Allpretty standard stuff I should think.
Dark Horizontal Lines
By daave in forum Capturing and VCRReplies: 4Last Post: 14th Aug 2012, 15:26 -
Horizontal distortion lines
By hyku1147 in forum Newbie / General discussionsReplies: 5Last Post: 27th Nov 2011, 10:02 -
Horizontal Lines Appear In DVD
By Mark-Leon in forum MacReplies: 33Last Post: 17th Oct 2010, 10:23 -
Horizontal Lines - Converting
By jooleyen in forum Newbie / General discussionsReplies: 5Last Post: 10th Mar 2008, 19:59 -
Help - Horizontal Lines
By Hiram_Abif in forum Newbie / General discussionsReplies: 8Last Post: 9th Aug 2007, 12:06
