hey all,
I am trying to create a cool looking 3d film reel with each frame on the film strip having either a video playing or the first frame of a video. Then inside after effects i would use the camera to animate a zoom in and around the film reel in 3d space to finish my animation.
so far i have created a front and back image of the reel, the roll of film itself to make it look like there's lots of film on the reel and a flat image of the film strip all in photoshop. the film strip i created is about 3 inches wide and about 30 inches long, the reel is about 10" by 10"
i've saved and imported all the files into after effects, placed them in 3d space where i would like them. I've even duplicated the front and back reel images about 4 times each and displaced them each times 1 from the first to give it some depth, i have the space between the front of the reel and the back of the reel equal to the width of the film strip i created.
Now i just need to fold that flat film strip around the reel, but i have no idea how to do that inside after effects. any help? rotation just rotates the entire thing. so i have no idea how to bend 1 side at a time so i can make it form a circle if i wanted.
thanks so much!
Bunt Studios!
http://precisionskatecrew.blogspot.com -
Don't believe you can easily do this without third party plugins. You might be able to fake it with a warp, but otherwise you probably need something like Zaxworks Invigorator. AE's 3D is fine for fly-bys of flat surfaces, but what you are doing is better done in a real 3D environment. Zaxworks isn't quite that, but it is closer than AE gets on it's own.
Read my blog here.
ok i'll look into zaxwerks invigorator, thanks. anyone else have any solutions?
Bunt Studios!
What is the best special effects/visual effects software?
By dzsoul in forum EditingReplies: 37Last Post: 10th Aug 2010, 00:16 -
After Effects: copy effects to another composition?
By squadjot in forum EditingReplies: 2Last Post: 8th Dec 2009, 20:16 -
need psd template for cd/dvd label
By wingfan in forum MediaReplies: 3Last Post: 22nd Dec 2008, 14:25 -
Jagged edges upon PSD inserting in PPro
By Vially in forum EditingReplies: 0Last Post: 12th Sep 2008, 17:34 -
CBT-100 TBC Causing 'Blurriness' and 'Hockey Stick' Bending?
By snivlle in forum RestorationReplies: 10Last Post: 11th Sep 2007, 20:44
