I have a powerpoint presentation and a video file from the real presentation. I want put the powerpoint slides into the video file. I tried to do this with Windows Movie Maker but it is almost impossible, because I don't want to split the audio when the relevant powerpoint slide is visualised.
Which software is the easiest way to combine powerpoint slides and video file?
I manage to export the slides to jpg, which OK.
I want to put the jpg files, but I don't want to stop the audio (while the presenter talks about a certain slide I want to show the relevant jpg image). -
My solution has been to use the jpgs as menus and put menu buttons on each slide to let the presenter click through the slides.
Camstudio works great but the presenter has no control over how long the slides are on the screen. (The person capturing it decides how much per slide) If that is how you want to go, it is a good program.
You have to use Camstudio if you want to include the animation in the slides.
Convert PowerPoint to Video
By TBaker14 in forum Newbie / General discussionsReplies: 7Last Post: 8th Nov 2011, 23:41 -
Powerpoint to Video Help
By annieo in forum Newbie / General discussionsReplies: 1Last Post: 2nd Aug 2009, 08:23 -
Powerpoint type video
By KyferEz in forum Newbie / General discussionsReplies: 3Last Post: 29th Dec 2007, 18:21 -
Powerpoint to Video Conversion software?????
By Etruria911 in forum Newbie / General discussionsReplies: 3Last Post: 8th Sep 2007, 20:13
