Is there any program that runs on the background and possibly cache video files with high bitrates so that they run smoother?
The reason i ask is cause i have a relatively old cpu 2.25 single core amd64 but i have 2 gigs of ram and maybe a cache saving application could make things better.
So far i have got to open task manager and terminate every process running on the background in order to run a 720p mkv, and i dont have plans to upgrade anytime soon.
I guess you have mkvs with h264 video? Then try a newer version of ffdshow or coreavc and play with Media Player Classic or Media Player Classic Home Cinema.
Caching wouldn't help, as the player would still have to play the cache. And assuming that it did, the video would play slowly (slow motion type affect) as your pc isn't fast enough to play in real time. The only solution is an updated player/codecs and/or a faster cpu.
Google is your Friend -
Originally Posted by Baldrick
The lightest players i use are media player classic vlcplayer and mplayer.
Does vlcplayer use coreavc or does it use internal codecs for h264 content?
Y do you thing that caching a litle portion ahead wouldnt work? -
Caching still requires cpu processing power to play the file,only a better cpu will help in the end.
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 18:17 -
Is the bitrate high enough?
By Weef in forum DVD RippingReplies: 23Last Post: 25th Jun 2009, 10:29 -
Low bitrate source to High bitrate target
By sameerdhiman in forum Newbie / General discussionsReplies: 2Last Post: 7th Nov 2008, 23:54 -
Mpeg2 artifacts at ~high bitrate.
By ronkkrop in forum LinuxReplies: 24Last Post: 13th Apr 2008, 15:06 -
high bitrate h.264 looks like junk???
By RadicalxEdward in forum Video ConversionReplies: 14Last Post: 12th Jan 2008, 20:38
