Hi.
For last few years, I've been using Hauppauge WinTV PVR-150 on my desktop (XP SP2, Pentium 4).
Now that I got a laptop (ACER Centrino Core2Duo, XP SP2, 2GB RAM), I wanna get a USB TV Tuner for it:
- Preferably costs RM200 (Malaysian Money) or less
- Preferably records in MPEG2 (like my PVR-150)
- Includes remote control if possible
- Includes software for scheduled/timer recordings
- FM radio not important but prefer the audio from the tv tuner to be in STEREO!
I've narrowed down to:
A. Smart TV PCMCIA Notebook Tuner Video Capture MPEG Card
Descriptions :
1) 32-bit CardBus / PCMCIA Type? analogue TV Tuner allow you to watch live TV and capture video on your laptop
2) Support worldwide analogue TV system : PAL / NTSC / SECAM
3) Full channel (supplementary channel contained) scanning, up to 125 TV channels receivable
4) Support high quality VCD/DVD compressing and recording
5) Additional video / audio input connector for cameras, VCDs, Camcorders, PS2, etc
6) Record TV / video perfectly to MPEG 1 / 2 / 4 and time shifting functions allow you to pause, rewind or fast forward live TV freely
7) Scheduled recording of TV programs
8) Support still image snapshot
9) Listen to FM radio on your laptop
10) Available channel preview is convenient for you to select right channel you want
11) The magnetic base of antenna is convenient to stick on metal surface firmly
12) Audio support NICAM / stereo / mono
13) Connector : 1 connector for TV antenna, 1 AV input connector for other video sources
14)Technical specifications :
* Philips TDA8290, TDA8275 new silicon tuner
* Video resolution of 720 x 576 ( PAL ) and 720 x 480 ( NTSC )
* Video capture rate : 25 frames / sec ( PAL ) and 30 frames / sec ( NTSC )
15) System requirement :
* Microsoft Windows 2000 / XP
* Pentium ? 500MHz or above
* PCMCIA / CardBus interface
* Microsoft Direct X 8.0 or above
* 64 MB of memory
* 500MB of available hard disk space or above
16) Size : Tuner ?11.5 ( L ) x 5.3 ( W ) x 0.3 ( H )cm, antenna cable length ?approximately 150cm
What will you get ?
1) 1 unit of PCMCIA TV Tuner / Capture Card
2) 1 unit of Antenna
3) 1 unit of AV Input cable
* CD-ROM with WinDVR OEM licensed software
* Installation Guide for Smart TV Card
B. WinTV USB Tv Tuner (Model 691 I think!)
http://www.hauppauge.com.sg/site/products/data_usb.html
I'm not sure if this can record in MPEG2 .. site doesn't say so!
No remote I think!
C. Gadmei USB TV BOX UTV 320/330 External TV Tuner With Remote
Specifications:
1. Support USB2.0/1.1, plug-and-play, support notebook and desktop Computer
2. With TV ANT/CABLE, AV, AVHS INPUT. Watch TV on PC or notebook pc.
3. Full channel scan, delete the unclear channel.
4. OSD function: display the information of channel and volume on the screen.
5. Time shift :it will help you record the favorite TV program at any time.
6. Adjust the picture size , highest resolution is 720*576
7. Capture high quality picture , the picture is smooth.
8. Support MPEG1/2/4 formats, easy to burn VCD/SVCD/DVD
9. 2*2-5*5 main menu display.
10. Full function remote.
11. User-defined brightness, contrast,color,tint.
12. Compatible with Windows 98 /Me/2000/XP, Compatible Direct X 8.1,9.0.
System Requirements
• CPU: Pentium4-1.8G or higher
• Operation System: Windows2000/XP/VISTA
• Interface: USB2.0
• Sound Card
I use want it mainly for recording from TV or Satellite so Audio / Video quality must be bloody good.
So if you got a USB TV Tuner, can you post a video sample (MPEG2 if you can) for us to see? Upload it somewhere like Filefactory.com.
If you like Hauppauge, why not stick with them? They have a PVR that uses USB. I'm not sure what the current one is, but I have the PVR USB2 and have been using it nearly three years now and still like it.
USB capture devices vs USB tuner devices...... which are better for recording?
By True Colors in forum Video Streaming DownloadingReplies: 1Last Post: 31st Jan 2010, 16:04 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 17:13 -
USB TV tuner
By Illusionist in forum ComputerReplies: 3Last Post: 26th Jul 2008, 05:38 -
Quality of a DVB/Tuner card ; but simplicity of a Capture card.
By BATGAL in forum Capturing and VCRReplies: 3Last Post: 1st Oct 2007, 11:51 -
Help with USB Tuner and Vista
By nickolasj80 in forum Capturing and VCRReplies: 2Last Post: 27th May 2007, 04:22
