Well I have my .mkv file. And many guided me to Xvid4PSP to convert to psp mp4 compatible format.
But the problem is, I get about 30-40 fps converting rate, and thus takes forever, has somebody tried something else
with faster converting? =D thanks.
Results 1 to 11 of 11
Encoding speed depends on CPU speed and the codec used. When I encode Blu-ray discs to MKV, the computer gets down to about 8fps and that's with a quad core CPU running at 3Ghz. The whole conversion takes about six hours. MKV>MP4 would be a lot faster.
You could try other programs, but if they use the same MP4 codec, the results would be about the same.
FWIW, speed and quality rarely go hand in hand. I would also suggest, if you are going to ask questions where the performance of your system is a key factor, that you fill in the computer details in your profile so we can see what you have to offer. Encoding is primarily a CPU based process, and while there are things you can do short of CPU replacement to speed things up, there provide only incremental improvement in most cases.
That said, a quick look in the Tools section reveals
PSP Video 9
PSPEnc
PSPVC
I don't have a PSP, so I cannot vouch for any of these personally, other than to say that they exist.Read my blog here.
Thanks for the help, and ya simply my machine isn't very strong.
Single Processor [2Ghz] and 512 RAM.
=] Appreciate the quick answers. -
My first recommendation though is to get it out of MKV. Most transcoders are not MKV friendly. Convert it to AVI, or if you can, MP4.
MKV: Merely Krappy Video.
Subbers, a request from an avid viewer: Either don't use mkv, or supply avi or mp4 as an alternative.
For those frustrated with converting MKV: http://www.immortalmusic.net/mkv/ -
Ya I totally agree with you, but then again converting to another format and encoding again may take nearly 2x it would take to convert directly.
lol, I remember encoding to MPEG-1 at 1fps (Pentium 100Mhz) xD
30-40fps sounds pretty much okay -
WinAVI has always sucked, been unstable, and a waste of money. The reason so many people seem to use it is a) it is easily obtainable without money changing hands, and b) the people who obtain that way get advised that it is the best by the people who facilitate the free distribution of it.
WinAVI has only ever worked by random chance.Read my blog here.
best mkv to psp and ps3 video converter
By ratboys in forum Newbie / General discussionsReplies: 3Last Post: 23rd Apr 2010, 21:21 -
mkv to psp help.
By 4ce in forum Video ConversionReplies: 6Last Post: 30th Nov 2008, 17:09 -
How to convert MKV to PS3 or PSP
By rjsax21 in forum Video ConversionReplies: 1Last Post: 12th Aug 2008, 22:11 -
[Help] How could i convert a MKV into a PSP-playable video file?
By rustix in forum Video ConversionReplies: 4Last Post: 12th Jul 2008, 11:23 -
help converting MKV to MP4 for PSP with subs.
By jag125 in forum Video ConversionReplies: 3Last Post: 21st Jun 2008, 05:08
