My capture card is: ATI All in Wonder 128 Pro
I have tried VirtualDub 1.4d & 1.4.5
This is what I get when I try to capture AVI file:
Video Driver-AMC peripheral not found AMC peripheral or cabling may be improperly installed.
VirtualDub capture error-Error 418:Capture device was not detected
VitualDub Error-VirtualDub cannot connect to the desired capture driver. Trying all available drivers.
VitualDub Error-PANIC:VirtualDub cannot connect to any capture device.
Thankyou
Results 1 to 20 of 20
you're using the new (crappy) WDM drivers. either get drivers 4.12.6292 or install the WDM-VFW wrapper. in 98/98SE/ME install webtv and uninstall it. or get old drivers and install only the wdmvfw.inf section of them (right click on that file)
I have had the same problem with running VirtualDUB. Tried both versions also. Have same error message: capture device not detected. Running/capturing with ASUSLive with no apparent problems related to this driver (yet)
Have the following:
msvfw32.dll 4.10.1998
vfwwdm32.dll 4.10.2222
vfwwdm.drv 4.10.2222
Could you give more info about 4.12.6292 drivers you referenced or specify which older drivers and where they can be had?
If this has been discussed elsewhere, I apppologize...
ASUS A7V
ASUS GEForce2 gts
256 mb ram
OS w98se -
I was able to use VirtualDub after installing this "wrapper"
http://shopgeo.virtualave.net/wrapper.zip -
Have the following:
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
first, make sure you registered the files into the registry. just copying them into the windows\system directory won't cut it. that's why i said to use the vfwwdm.inf file to install.
the 4.12.6292 drivers are for the ATI aiw 128 pro, not the asus cards. if you have win98, i think you can get the wrapper by installing & uninstalling webtv -
patrickm....I did not copy these files into my system folder, however, the only file I see referenced in the registry is:
vfwwdm.drv
Should the others:
be there also? If so, how would I do this?
Also, to Stinky: which capture card are you using? Does the wrapper affect any other "currently functioning" programs
ASUS A7V
ASUS GEForce2 gts
256 mb ram
OS w98se -
I installed it blindly (not that I'm reccommending you do that) on my w2k system
the only thing I noticed was that I could now capture with VirtualDub --- nothing else was affected -
After "looking in the wrapper" it seems I do have versions of these drivers, but virtualdub cannot see them????
Is this right? And if so, how can I make vdub find them? Since the ASUSLive program is functioning, along w/Pinnacle Studio7, I hate to install more new drivers unless necessary!
Thanks,
kristin
That smoke you smell is coming from my ears. I understood install and uninstall WebTV and that did not work (thanks anyways PatrickM). I downloaded the wrappers Stinky suggested but now what do I do with them? I am a complete newbie if you have'nt alredy guessed. I tried capturing with my Media Studio Pro and I got the same message. I have had more problems with ATI and there drivers than all the other software combined. Should I try a different video and capture card or try to figure this one out. If so please suggest one.
Thanks for all the help so far. -
right click on the file that ends in .inf and select install
thats all you need to do
Thanks for the quick response Stinky. They loaded but VirtualDub still comes up with the same error "AMC peripheral not found". Should I put the old dll & drv files back?
put the dll & drv files back where? when you use the vfwwdm.inf file to install/register the other files, you shouldn't have to move them anywhere.
what ATI drivers are you using? what OS?
ALSO, USE THE RIGHT VERSION OF THE WRAPPER. files for winNT/2K will have version #'s like 5.x.xxxxx and ones for win95/98/98SE/ME will have 4.x.xxxx or 4.9.xxxx (generally for 98SE/ME but not critical either way). if you don't use the right set they don't make the right function calls and may not work right, or may work poorly
if after this you still get a NO AMC peripheral, i think you installed the drivers wrong. check your device manager and make sure no components of the ATI card have yellow (!)'s on them. -
Thanks Patrick. One of my ATI devices was yellow so I reinstalled the ATI drivers and it works now. I told you I was a rookie, no answer is too simple.
I am not sure the Microsoft wrapper will work. This is because Microsoft says in W98 it works only for capture devices on USB or 1394. See page below:
http://support.microsoft.com/support/kb/articles/Q192/1/12.ASP
I have the same problem: installed the 2 vfwwdm files in the C\windows\system directory and Virtualdub will not see them.
So, I am still looking for a wrapper for my AIW128Pro.
Arepiv -
Uhhh...
This might be kinda stupid... If so, just ignore me or throw a rock at me or something
I had the same problem of VirtualDub still not working with my ATI card even after installing Stinky's wrapper... Heh... But that was my fault because during the installation, I was asked if I wanted to replace a newer version of a driver with an older one and I said no. Once I re-installed and selected yes, VirutalDub started working perfectly...
Another thing is that you need to go into the Video Source menu under Video. The first pull down menu should have identified your card, but the second pull down menu will be empty. Here you need to select whether you're using a Composite, Tuner, or S-Video input. Once you select the appropriate one you should be in business
I installed Stinky's wrapper and now I am able to capture with Virtualdub, AVI-IO etc. Thanks Stinky !
All this was to see if using this configuration (WDM driver with VfW capturing programs) would get rid of my artifacts. In fact it didn't ! I'll post a new message here, my previous one had no replies !
Arepiv -
yeah, that's what i meant about making sure you install the right versions. when i reformatted my drive, somehow i ended up with versions 5.x.xxx of the ks*.ax drivers in winME. even though the 5.xx ones are actually older, they have a higher number by virtue of being for the NT kernel. -
i got the wrapper
and i have vfwwdm32.dll
vfwwdm.inf
vfwwdm.drv
when i install the inf like you guys said it says cannot locate the first file (vfwwdm32.dll) and its in the zip or is t in the ati folder somewhere
i have win2k so the link at stinky gave is it the right link for win2k??
im really dumb can someone go step by step on how to install the wrapper ;x -
unzip all 3 files into your winnt\system32 directory
right click on the .inf file and choose "install"
Weird Interference ATI AIW Pro
By Tom Saurus in forum ComputerReplies: 8Last Post: 7th Aug 2010, 10:52 -
ATI AIW 9700 pro capture card problem
By INFRATOM in forum Capturing and VCRReplies: 8Last Post: 31st Mar 2009, 12:26 -
ATI AIW 128 720x480 mpeg captures have horizontal tearing
By cybertheque in forum Capturing and VCRReplies: 16Last Post: 17th Sep 2008, 21:53 -
Populating empty ATI VIP / AMC feature header on AIW Rage 128 Pro
By cybertheque in forum Capturing and VCRReplies: 3Last Post: 14th Sep 2008, 16:36 -
Didn't ATI All in Wonder 128 Pro have Mpeg capture?
By Ensign in forum Capturing and VCRReplies: 7Last Post: 7th Mar 2008, 10:13
