Just import them into Elements. It should work.
If it works, you can skip Virtualdub.
Results 31 to 34 of 34
http://www.kiva.org/about -
I imported the audio and video pieces into Elements and then exported them to an mpeg. It got to 99.99% complete, and now is just sitting there. I guess Ill wait a bit. Is there a better way to join the audio and video clips?
I don't know about the 99.9% but so long as you don't get lip sync issues, separate audio is fine.Originally Posted by hygieneboyRecommends: Kiva.org - Loans that change lives.
Just something that has not been mentioned, but the OP is aware that most DVD players will require the MPG format, and files converted to DV-AVI will have to be encoded again to MPG?
Unless your DVD player plays Xvid (also an AVI), but these would have to be encoded a second time, as well.
Also, weren't the Sony VOB files somewhat non-standard, such that some programs had issues with them?
Best way to convert VOB to AVI or other type without any quality loss
By mikej411 in forum Video ConversionReplies: 4Last Post: 16th Nov 2011, 12:56 -
How to convert vob to avi without loosing video quality ?
By RON36 in forum Video ConversionReplies: 4Last Post: 31st Oct 2011, 08:56 -
how do I convert .divx files to .avi without loss in quality
By Onceler2 in forum Video ConversionReplies: 2Last Post: 17th Oct 2009, 10:03 -
Verbatim disks are made by Taiyo Yudenv==== True or False ?
By bendixG15 in forum Newbie / General discussionsReplies: 16Last Post: 5th Feb 2008, 20:52 -
Simple Question: True or False?
By jcm0320 in forum Capturing and VCRReplies: 10Last Post: 23rd Aug 2007, 22:33
