I have a hp 740b dvd writer and it won't recognize 16x discs and it should. I've tried uninstalling the driver and also updating the driver with no luck. I'm desperate and any help would be greatly appreciated. The highest I can read is 8X on DVDs. It reads CDs just fine. I even tried a different dvd drive so I don't what else to do
did that also. didn't work. and the drive used to recognize these very discs that it won't now
I thought that it might be going bad but I put my son's drive in my computer and it's doing the same thing. It's got me downright agitated. I've got all these packs of DVDs that no longer work in my recorder
Media brand used ?
Speed of burns used initially ?
Access another system to test ... Lg dvd burners are less picky ... if failure ... media is considered obsolete and files are gone.
On hardware side, try replacing the data cable connected to burner with a known good cable ... some develop problematic communication issues. -
LG DVD burners are more picky, if anything. A number of them have problems with good media, such as Verbatim. That's unacceptable. The OEM versions are the real culprits, too.
The laser indeed sounds dead. Replace it.
Get a Sony, Samsung or Pioneer drive. Buy online for $20-40.Want my help? Ask here! (not via PM!)
"can't read disc, check disc" problem
By ttheb1 in forum Authoring (Blu-ray)Replies: 1Last Post: 13th Jun 2010, 06:34 -
Can a 4x burner write to a 16x disc?
By bobarnett in forum DVD & Blu-ray RecordersReplies: 10Last Post: 24th Sep 2008, 15:47 -
help, for read dvd disc with 16x
By flowerhorn in forum Newbie / General discussionsReplies: 8Last Post: 29th Jul 2008, 09:35 -
Best Buy Verbatim - 50-Pack 16x DVD-R Disc Spindle $12.99
By sknox in forum MediaReplies: 5Last Post: 16th Mar 2008, 20:46 -
I/O Magic DVD ReWritable 16X Drive Not running at 16X
By mmitsch in forum DVD & Blu-ray WritersReplies: 3Last Post: 6th Jul 2007, 23:40
