I am working on a Christmas DVD and would greatly appreciate someones help!!!
I am using DVD-lab Pro 2. I have a motion background with the words already set in the motion. I also have three animated buttons (They are rotating christmas wreaths). Next to each "title" in the motion background. The background behind each wreath is black. My plan was to draw a black rectangle around each wreath and set the "unseen" black rectangle as the button. I thought if I selected invisible selected the box would go away revealing the wreath underneath which would then look like the button though its actually just part of the motion background. Any way to do this? I assume I'm not setting the color buttons correctly...
Jeff
Any help would be greatly appreciated my wife is on my case to get this project done!!!
I don't think you can do it that easily. I have had a play, and basically you can't have a black button that turns on and off. I have had a play with all sorts of settings and cannot find a combination that works.
The best I can suggest is that you duplicate the menu a few times, add rectangles in all the combinations of on and off, and then create switched menus. Not complex, but time consuming.
You might also post at the MediaChance forums to see if someone there has a better solution.Read my blog here.
Thanks for the quick response as always.
I remember asking on the forum before about doing something similar and that was how the person suggested. I ran out of time and had to switch to something else so perhaps it wouldn't have worked anyway...
I've never been a fan of switched menus. They seem slow and you can't put music to them. I'll keep trying and let you know if I discover anything.
Jeff -
If you use cells for your menu they are much faster, although music is still an issue, and it only really works well for still menus.
You could try putting a frame, rather than a solid block, over the items in question, then setting your button colours to black for unselected and clear for selected. Might work.Read my blog here.
Maybe this is what I was thinking of...
http://www.mediachance.com/dvdlab/tutorial/inverse.html
Its invisible Normal not invisible selected!!
Thanks again. I already did it and it worked like a charm. -
The problem with this is that once a button is selected and the player decides to play a title, all 8bits will disappear for a split second revealing all your underlying background. - Really ruins the effect....problem persist from player to player.
"DVD Lab Pro"/DVD Authoring for Mac?
By Paker in forum MacReplies: 4Last Post: 8th Aug 2011, 01:50 -
Add a menu to a DVD without re-authoring, using DVD-Lab Pro
By petar in forum User guidesReplies: 38Last Post: 12th Mar 2008, 12:22 -
DVD Authoring with DVD LAB PRO doesnt create all files
By SSJ4Thiran in forum Authoring (DVD)Replies: 16Last Post: 18th Feb 2008, 10:03 -
Help with DVD-lab pro
By Jack the Ripper in forum Authoring (DVD)Replies: 1Last Post: 4th Dec 2007, 07:21 -
Q, for those who use DVD Lab Pro...
By GangstaRap in forum Authoring (DVD)Replies: 3Last Post: 1st Nov 2007, 06:15
