I have converted a .TP0 file from a PVR to mpg format with MPEG Streamclip plays OK in most applications including Videoredo but WMP and some minor applications refues to play and or encode into other formats such as avi.
I have drawn the following info with mediainfo
I hope you guys can help me unravel the mystery
Thank you
Format : MPEG-PS
File size : 1.33 GiB
Duration : 39mn 39s
Overall bit rate : 4 812 Kbps
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings, Matrix : Default
Duration : 39mn 39s
Bit rate mode : Variable
Bit rate : 4 286 Kbps
Nominal bit rate : 5 000 Kbps
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 16/9
Frame rate : 25.000 fps
Standard : PAL
Colorimetry : 4:2:0
Scan type : Interlaced
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.413
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 2
Duration : 39mn 39s
Bit rate mode : Constant
Bit rate : 192 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Resolution : 16 bits
Thank you but
is it nice if I had an option to install MPEG2 decoder in Windows XP then everything would have been possible without a problem. -
If you need a MPG-2 codec for WMP, you could try Stinkys MPEG2 Codec.
Stream Transport
By Soixante in forum ComputerReplies: 4Last Post: 4th Apr 2014, 05:05 -
Problem converting from MPEG Program Stream to Transport Stream
By vivajam in forum Newbie / General discussionsReplies: 5Last Post: 24th Jan 2011, 04:40 -
MPEG-2 Transport Stream ...
By DeathStalker77 in forum DVB / IPTVReplies: 3Last Post: 26th Feb 2008, 22:22 -
need MPEG2 Transport stream and Program stream profiler
By afarun in forum ProgrammingReplies: 3Last Post: 23rd Aug 2007, 01:06 -
MPG to transport stream - my finds (projectX)
By T12345 in forum Video ConversionReplies: 0Last Post: 28th Jun 2007, 01:57
