I've bought on ebay a JVC HR-S7955, that, according to the manuals at
http://books.jvcservice.com/booklist.asp?Model=hr-s7955
contains TBC/NR, digital 3R, BEST, video stabilizer etc.
However, my ebay purchase doesn't come with a remote. Do I need a remote in order to access these advanced menu functions, or can I just navigate through the menu options using the front-end controls of the VCR itself? You guys with a JVC HR might know this answer...
In case JVC option-programming requires a remote, can I use a generic remote? or a remote from any other JVC? any cheap remote would do fine, since I'm just doing some restoration of some old VHS tapes (so I just need stop/play/rewind/tbc etc), and do not intend to use this JVC for day-to-day recordings etc.
Thanks a lot for any advice,
Leon
In this model to access these features you must go in menu. It can be done with remote, original or compatible. In most JVC VCR TBC function is activated by a button on the front side. Your model lack this button. So, you need the remote.
JVC SR-V10U remote control
By bigvlad12 in forum Newbie / General discussionsReplies: 2Last Post: 31st May 2011, 14:49 -
How to program remote control for BDP-S370
By Dankriss in forum DVD & Blu-ray PlayersReplies: 5Last Post: 15th Mar 2011, 03:21 -
Remote control JVC Everio GZ-HD10U camcorder.
By 872156 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 10th Jun 2009, 17:51 -
How to enable the program button on remote control using VIDEO_TS.IFO
By kraw in forum Authoring (DVD)Replies: 4Last Post: 26th Sep 2007, 22:59 -
How Customize Menu Navigation in order to let the remote perform functions?
By wan2no in forum Newbie / General discussionsReplies: 3Last Post: 24th Jun 2007, 10:33
