My DVD Player will not play SVCD's so I am attempting to convert an SVCD to an XVCD which it will play. I rip the file structure from the bin image, then I use TMPGenc to convert the resulting .mpg from SVCD to XVCD. I am using a 480X480 size and have tried everything from 1800 to 2400 as the bitrate. I set the stream type to VCD non standard. Then I go into MPEG tools and use the simple multiplex feature. The resulting MPEG is created and when played on the PC the audio is fine. When I burn it with nero using the non standard video CD option, and it is able to burn. But when I play it in the DVD player, the audio is out of sync by about 1-2 seconds. I have tried demultiplexing it to audio and video and then remultiplexing, it still did not work properly.
I have a SONY DVP-NS300 DVD Player.
Here's something you may be very interested in, and would save you alot of time!
http://forum.doom9.org/showthread.php?s=&threadid=16404
Let us know how it works for you :o) -
This is what I am doing, the one difference is that I am using non standard MPEG 1 rather than standard MPEG 1. I will try standard tonight, maybe that's what is throwing it off. But some people at the bottom of that thread were saying they had audio sync problems with this method...
I also see from this thread that it doesn't convert anything, it just changes the header. I noticed that today myself, when I looked at the new mpeg it still was an MPEG 2. If changing the header type to standard doesn't work, I am going to demux it tonight, convert the video to MPEG 1 and remux it and hopefully that'll work.
If anyone has other suggestions or a step by step on the best way to do this, it would be appreciated. I am a newbie to this stuff... -
Thanks Warthawg,
It's working!!! I had to do two things. First I used the standard VCD header rather than non standard. I then tried to burn in nero. My DVD player wouldn't even read it. Then I burned the same mpg with VCDEasy and it worked like a charm!
I am using XP, guess there are problems with Nero in XP...
.ts to XviD with AutoGK: Some audio probs?
By vieekk in forum Video ConversionReplies: 0Last Post: 8th Feb 2012, 12:02 -
(avstodvd) Converting m2ts to dvd...sudden sync probs.
By newbtube in forum Video ConversionReplies: 17Last Post: 3rd Apr 2011, 00:27 -
Audio sync probs
By just_kim_usa in forum Video ConversionReplies: 2Last Post: 27th Jan 2011, 15:23 -
video and audio sync probs
By reynardthefox in forum Newbie / General discussionsReplies: 3Last Post: 3rd Mar 2010, 01:23 -
svcd/mp3 probs w/new players
By blujayhill in forum DVD & Blu-ray PlayersReplies: 6Last Post: 17th Jun 2009, 11:28
