Before the NXE came out my xbox could see mpg, mpeg files on my PC but now it know longer can it still sees avi and wmv of couse.
Anyone else notice this?
Are you going through the video library tab?
I popped in a mp4 video file after the update and it required me to download a patch (2.4mb) for reading unprotected AAC and mpeg4 video files.
I'm not sure if you have downloaded this patch or not. I frankly don't know how you would go about doing it manually. I would check xbox.com for a tech support on it.
Or there is always google for more info on media updates on the 360 (though I personally use yahoo first and then fall back on google if it takes me awhile).Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
I took a .VOB file from a DVD renamed it to .mpg and the 360 would not see it. Before the NXE came out doing that would work i belive?
Sorry I can't confirm that as I never tried it.Originally Posted by David97
I don't believe the 360 was that versatile. I know the ps3 can read vob files directly off disc. I think the 360 is much more strict on what it can do. Like you said it does wmv perfectly as that is the native Microsoft architecture.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Help to convert MPG to an Xbox 360 Format?
By lovelylisa in forum Video ConversionReplies: 7Last Post: 13th Jan 2012, 03:23 -
how do you record xbox 360 gameplay while using microsofts xbox 360 vga ?
By rushinplaya in forum Capturing and VCRReplies: 18Last Post: 3rd Apr 2010, 07:19 -
XBOX 360 + MPG + Subs
By leceur in forum Video Streaming DownloadingReplies: 3Last Post: 15th Dec 2008, 17:07 -
Need felp converting MKV file so it plays on Xbox 360
By wwervd316 in forum Newbie / General discussionsReplies: 6Last Post: 7th Mar 2008, 23:29 -
Can you interchange a xbox 360 hddvd drive between pc and 360?
By yoda313 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 23rd Oct 2007, 10:06
