Results 1 to 22 of 22
    Jul 2006
    Title says its all. I've looked at
    • Kodak Zi6
      Creative Vado HD
      Flip Mino Hd
    I like Kodak's option of 60 fps. But I also need a camcorder able to record well in low light. Space is also an issue I'd like 4 hours of recording in HD. If its SD card or internal, its fine. What do you guys think or do you ahve other suggestions?
  2. What are you doing, snowboarding at night? All snowboarding i've ever seen has very bright conditions, not low light conditions. Canon hd camcorders have been said to have good low light capabilities.
    Jul 2006
    Our mountain, has night skiing until 10 PM. I usually go from 4 - 10. Though every month i take a whole day trip to a mountain out of state.
    Jul 2006
    Nothing else?
  5. they all suck in low light
    check the reviews on amazon.com
    http://www.amazon.com/review/product/B001BO7R00/ref=cm_cr_dp_synop?_encoding=UTF8&show...R19UT19PL91GRR
    Cons:
    -Not as small and light as a Flip Mino
    -Mediocre-Poor Video Quality in low light situations
    -Makes annoying sounds when turning on & off
    -Controls, while functional, are somewhat clunky
  6. Member Soopafresh's Avatar
    Jan 2004
    I like the Flip Mino HD. It's not that bad in low light.
    http://www.vimeo.com/2512239
    Great comparison of ZI6 to the Mino HD
    http://www.vimeo.com/2259235
  7. i don't think you ganna see many store/street lights when you snowboarding
    Jul 2006
    Yea just checked out that vid, interesting that Kodak has a much better color balance than the Mino
    go to
    http://www.wachusett.com/TheMountain/Services/NightSkiing/tabid/74/Default.aspx
    check out the pictures. You will be amazed at how many light there are.
    Cons:
    I'm ditching the pocket sized camcorder, because truthfully they all do really suck. (Like you said)
  9. Member Soopafresh's Avatar
    Jan 2004
    Heh. You're probably right.
    Check out the 6:00 mark of the second video I posted above. The biggest problem with these tiny camcorders is the horrible rolling shutter problem. It's like looking through a Jello sculpture. And THAT is going to be bad news when you're speeding down a big hill.
  10. RCA EZ300HD looks very interesting but I don't think this class of cameras worth more than $99
    http://www.vimeo.com/2234517
    Jul 2006
    I may not have to leave of the pocket camcorder, check this out
    http://www.bestbuy.com/site/olspage.jsp?skuId=8940015&type=product&id=1215217076309
    I'm looking for video tests.
  12. check your local stores if the have it.test it and if you don't like the results return it
    btw .the RCA got built in HDMI
  13. Originally Posted by Squid267
    same complains low light issue,and fast movment
    I think bestbuy was selling it for $99
    I may get one for the heck of it.
    Jul 2006
    I'm checking out that RCA. Dam I didn't know there were so many pocket HD camcorders.
  15. amazon.com is out of stock.The RCA comes with 2GB Internal(Insignia only 64mb lol0 Memory,Expand recording with up to 16GB(Insignia one only 8gb)and Built in HDMI
    Jul 2006
    Thanks for showing me this. I'm seriously considering this now. I've seen a couple of tests looks superb.
  17. you may wanna check more reviews 1st .lol
    like I said buy it,test it,and if you don't like it return it (just be sure they don't charge %15 return fee )
    http://www.circuitcity.com/ccd/ExpandedModule.do?oid=220713&callingModule=9#custRatings
  18. Member zoobie's Avatar
    Feb 2005
    Florida
    they light the slopes at night...as well as golf courses...usually the par 3's
    Jul 2006
    How bout the Sanyo HD1000? Any glaring issues I should be concerned of before purchasing it? I know it record naively in mp4. Also is 60 fps only for 1080i? or 720p also? This is $399 http://www.fotoconnection.com/p77906-sanyo-xacti-vpc-hd1000-hd-camcorder-1-25-cmos.html. BTW <-- is this source reliable?
    Jul 2006
    Wow, good thign i didnt order there!
