I know there should be a simple way to do this but I don't know what it is.
I have about 7000 files totaling approx 17gig.
I need to back them up to dvd's.
Is there software that will just let me select all of the files and back them up to multiple dvd's automatically?
Results 1 to 13 of 13
Try imageburn. It has burn from folders options. I don't know about automatic disc spanning though.
Certainly nero would have that option - also try roxio.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
yoda, can't find anything like that in Nero although I admit I did not spend a longgg time looking...looked at Roxio's site...
"Span large files and projects across multiple CDs or DVDs"
So Roxio is an option.
hech54, thanks to you as well...looks like DVD Span is designed to do specifically what I want and is quite cheap.
I will have to look into the 2 and decide.
Thanks guys. -
You will need the help of your children and grandchildren to complete this project after you pass on.
Why not stay with hard drives?Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Nero will autospan just like Roxio. Just drop them in place and start the burn, it'll prompt for another disc when needed. Personally, I'd take a few moment and manually move them into separate folders totaling about 4 gigs or higher if you are using dual layer discs. It really shouldn't take long to do this.
Just a secondary back up. Everything important is kept on a 1TB external that is in a fireproof/waterproof safe. Dvd's are just a non mechanical redundant alternative....hard drives can fail.Originally Posted by edDV
PoppaMeth....what version of Nero are you using...I still have 6...I don't think it does that? -
I'm using 6 as well. The latest build of it. I could be wrong on this. I swear I've done it before but it was only once. It might only work for certain types of discs as well. I was making an audio CD if I recall correctly. If I get some time today I'll test it.
I had a similar question a while ago. The solution was to use Nero 'Back it Up' in version 6 . This will do spanning and keeps all of the folder structures intact. I moved the folders to the root (C:\_) to keep opening of folders on the burned media to a minimum.
--dES"You can observe a lot by watching." - Yogi Bera
http://www.areturningadultstudent.com -
Maybe I'm wrong but doesn't BackItUp store the files in a .nbi image file? Supposedly it preserves the folders but compresses them into an image file before writing. You can supposedly browse the resulting disk via explorer but I think you have to actually extract the files to use them.
You're right, but in preferences you can turn off compression and then is saves the regular files/types without creating an archive. I should have mentioned that when I posted.Originally Posted by Poppa_Meth
Uncheck the 'Compress files before backup' option in Preferences -> Back up.
Good to know. The help files don't seem to make this clear at all.
I've noticed help files are usually attempted by the programmer(s) themselves...hardly writers with any real communicative experience...some can't write any help file...it's way beyond them...but can be found on match.com
Merging/Converting Multiple M2TS files to MKV With Multiple Audio Tracks
By Nicholas S. Folsom in forum Video ConversionReplies: 1Last Post: 13th May 2011, 19:34 -
Price level on (almost) new Signvideo DR-1000 and Datavideo TBC-1000
By Northpole in forum RestorationReplies: 3Last Post: 24th Jan 2011, 13:02 -
Multiple AVI files to multiple DVD discs, no quality loss, chapter per avi
By Delta007bhd in forum Video ConversionReplies: 11Last Post: 14th Apr 2010, 09:27 -
burning multiple mp4 files to DVD format
By dvdnewbie64 in forum Newbie / General discussionsReplies: 2Last Post: 20th Mar 2009, 14:59 -
Burning multiple .MDF files to DVD
By henry13 in forum MacReplies: 10Last Post: 26th Jan 2008, 14:01
