im trying to remove norton from my aunts computer, its a vista. when i go into the menu i click on the uninstall button it stars gathering system information. after the system information bar is done loading it says that norton cannot be installed, please contact the norton web site. is there a way on vista that i can remove it manually by going into the system manually?
We don't stop playing because we grow old; we grow old because we stop playing.” (George Bernard Shaw, 1856-1950)
use the icon and click on disable auto protect, then go to services and turn off and disable the services. reboot then go to add and remove. make sure you login as administrator.
The only way to get rid of it is deleting all the entries in the registry. Any other way you are waisting your time. Not even the norton removal tool gets rid of it.
Oh, that sounds really bad, I use norton on my laptop also, and it is going to exprire, I am going to remove it, hope things will not be that hard.
Norton is great at being a real pig to remove totally from your system, even by hand using other means it takes ages and leaves plenty of rubbish on there so it still tries to run things that don't exist anymore causing errors when you start your computer
Even using their own software uninstallers doesn't guarantee it will remove everything, its even worse if you get a partial install, why can't software companies write decent uninstallers then we don't have to use other software to remove their rubbish
Anyway, Norton have provided a free util that will remove their badly uninstalled software totally from your system
Snag is it will remove ALL Norton software fgrom your system, so if you use other Norton software it will also uninstall and delete that as well. Well, why bother writing it properly to be selective lets just do the easy thing and delete everything that way we will get no more complaints
Click on the link below, run it and let it scan your system. It may take quite a while as it does do a very good job of removing it, but then again if it was done correctly in the first place ............
ftp://ftp.symantec.com/public/english_us_canada/removal_tools/Norton_Removal_Tool.exe
It won't install the software, just says its installing it, so you don't have to worry about even more crud on your computer
Its capable of automatically and annoyingly removing all the following software from your computer, regardless if you only want some of it removing. So be aware of this 'feature'
· Norton AntiSpam 2004/2005
· Norton AntiVirus 2003 through 2009
· Ghost 10.0, 12.0 and 14.0
· Norton GoBack 3.1 through 4.2
· Norton Internet Security 2003 through 2009
· Norton Password Manager
· Norton Personal Firewall 2003 through 2006
· Norton SystemWorks 2003 through 2009
· Norton Confidential Online 2007
· Norton Internet Security Add-on Pack 1.0 to 3.0
· Norton Save and Restore 1.0 to 2.0
· Norton 360 1.0 to 2.0 -
PhenII 955@3.74 - GA-790XTA-UD4 AM3 - 2x4 Corsair Vengeance@1600 - Radeon 5770 - Corsair 550VX - OCZ Agility 3 90GB WD BLACK 1TB - LiteOn 24x - Win 8 Preview - Logi G110+G500
Under vista > control panel > programs and features > uninstall from here only
Do you use Norton anti-virus or freeware of something else?
By beavereater in forum ComputerReplies: 26Last Post: 31st Jan 2011, 22:34 -
Norton Antivirus 2010 message
By jyeh74 in forum ComputerReplies: 5Last Post: 23rd Jun 2010, 00:01 -
norton and spybot
By janefield in forum ComputerReplies: 5Last Post: 20th Mar 2009, 05:32 -
Norton Ghost 14 Advise
By Squid_uk in forum ComputerReplies: 9Last Post: 21st Oct 2008, 13:24 -
Dash you, Norton
By JohnnyMalaria in forum ComputerReplies: 10Last Post: 7th Dec 2007, 21:04
