HI, I have looked every where for an answer but with no luck so here is my question:
I have a .mp4 and a .ac3 file. I can use media player classic to play them together using open file and the dub option for the .ac3 then seleting it as the play back stream.
I want to join these to one file. I used gdsmux to do it and got a .mkv file (as i wanted) but the audio loses sync (getting worse as the movie goes on). Any idea why this would be ? or am i doing something wrong ?
So playing in Media Player Classic - No loss of sync
Convert to .mkv with gdsmux - Out of sync getting worse the longer the move goes on.
If the files play in sync in Media Player Classic when separate, then the delay of the audio is zero either way. GDSMux is buggy; you will have better luck using MMG (MKVMergeGUI) from the mkvtoolnix package. Be sure to set either a display frame size or aspect ratio in the GUI if your source MP4 file is anamorphic.
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 11:19 -
Loss of frames when playing mkv/mp4 etc
By periodrage in forum Software PlayingReplies: 6Last Post: 16th Jan 2011, 15:45 -
replace ac3 2ch with ac3 5.1 ch in mkv (and sync)
By umbbra in forum AudioReplies: 1Last Post: 12th Jun 2010, 04:18 -
join H.264 mp4 with a AC3/DTS/LPCM audio stream
By xrlem01 in forum Newbie / General discussionsReplies: 3Last Post: 29th Apr 2009, 08:09 -
how to fix: MKV to MP4 with bad ac3?
By cjh1452000 in forum Video ConversionReplies: 2Last Post: 28th May 2008, 03:11
