does anyone have this working? i've installed vista codec pack which claims to enable it, but it's not working for me. i did it on a clean install of windows too, where i just had to remove ffdshow and coreavc before installing it, so i shouldn't have any codec conflict problems. i posted a topic on his forum about it, he said to reinstall it with the custom options and to not install AC-3 filter, which i did but it still didn't work. i posted my results there but haven't heard any more back on it.
working for anyone?
thx,
rlr
I found that if you go into ffdshow audio decoder, you need to set the output, under mixer->output, to enable 24 bit support (keeping 16 bit also). dts-ma will now work fine, dd thd is still kinda buggy, it'll play the standalone audio file fine, but won't always in the container, continuing to work on it.Originally Posted by aedipuss
rlr -
why does the dd thd work on a standalone thd file, whereas when I mux one into a m2ts container it won't play??
Hellow runLoganrun I have been having this problem with zoomplayer. I'm in the middle of an encode so I can't try your suggestion from 2 years ago. Has there been any updates to this?
Dolby Pro Logic vs Dolby Digital?
By therock003 in forum AudioReplies: 17Last Post: 11th Jun 2011, 20:51 -
1080p true hd to 720p true hd possible ?
By miss in forum Video ConversionReplies: 2Last Post: 16th Jul 2009, 22:48 -
Is Dolby True audio and Uncompressed PCM worth a new receiver?
By yoda313 in forum AudioReplies: 7Last Post: 20th Apr 2008, 12:25 -
Can you add on a dolby true hd processor to exisiting 5.1 system?
By yoda313 in forum Off topicReplies: 6Last Post: 15th Nov 2007, 18:38 -
How to downconvert Dolby Digital to Dolby Pro Logic II?
By randyharris in forum ffmpegX general discussionReplies: 0Last Post: 2nd Nov 2007, 17:54
