Hi and thanks to anyone who's willing/able to help me on this one.
I was having problems with my old ffmpegX after having downgraded from OSX.5 to OSX.4. It would run through the encoding process but no encoded file could be found. I decided to delete the old ffmpegX components, including the ffmpegX folder in HD/Libraries/Application Support and start from scratch. I downloaded the ffmpeg_0.0.9y installer and the necessary codecs and installed them on ffmpegX.
When I tried to convert a .flv file to .mp4 I got no progress bar and a window asking which program to use for something to do with 'Progress'. I checked the new HD/Libraries/Application Support/ffmpegX folder and noticed that something I'd seen in there before called Adobe Acrobat or something was missing so I selected Adobe Acrobat 7.0 from my applications and the progress bar returned. The conversion completed but this time the same file which wouldn't work before now came up with 'failed' in the progress bar.
Below is the information from the progress bar.
Should I have selected a different application to run the progress bar?
Any suggestions about what the problem might be?
Encoding started on Fri Dec 12 20:14:47 EST 2008
MEncoder dev-CVS-051126-18:35-3.3 (C) 2000-2005 MPlayer Team
Mac OSX static build for ffmpegX
AltiVec found
CPU: PowerPC
success: format: 0 data: 0x0 - 0x2db79e
libavformat file format detected.
Unsupported video codec (4)
[flv @ 0x72d500]Unsupported video codec (4)
[Then a huge stream of the last line repeated over and over until...]
LAVF_header: av_find_stream_info() failed
============ Sorry, this file format is not recognized/supported =============
=== If this file is an AVI, ASF or MPEG stream, please contact the author! ===
Cannot open demuxer.
Some users that also had that "Where is Progress.app?" message, pointed it to ffmpegX itself, as Progress.app is an application inside the ffmpegX program package.Originally Posted by Fostermeister
Acrobat is unrelated to ffmpegX, so this seems wrong, but I see that Progress.app was still activated. Hmm, quite forgiving, /me thinks...Originally Posted by Fostermeister
mencoder/mplayer seem unable to read the video codec used in the FLV file. FLV files can have one of a variety of video codecs, H.263 being very common (and well supported by ffmpegX), but others can be found, like On2 VP6.Originally Posted by Fostermeister
I would suggest installing Perian (a QuickTime decoder component, which supports many FLV flavors), then converting in ffmpegX with an ffmpeg preset (not mencoder) and activate 'Decode with Quicktime' in the Options tab.
VLC Player's "record" feature- can I change the output folder?
By gastrof in forum Newbie / General discussionsReplies: 1Last Post: 30th Mar 2012, 00:32 -
Was it the iphone that replaced the word "program" with "application"?
By yoda313 in forum Off topicReplies: 6Last Post: 16th Mar 2011, 09:52 -
no application support folder
By snookie in forum ffmpegX general discussionReplies: 1Last Post: 26th Jul 2008, 16:15 -
HD bitrates & 1.8" HDD support
By nalooti in forum Portable VideoReplies: 6Last Post: 10th Dec 2007, 10:43 -
Whats "application/x-pn-imagemap"?
By eu63ne in forum Newbie / General discussionsReplies: 4Last Post: 8th Oct 2007, 09:50
