  1. Banned
    Nov 2006
    USA
    I just installed new hard drive. It installed and formatted (long format) fine. I put it under heavy load yesterday for the first time, copying 80GB of files over to it, and it was occasionally making some noises (ticks, hums etc). It stopped happening after about 40GB into the transfer.
    Are these sounds something I should be worried about or are they "normal"? Should I return this drive? My OS doesn't run off this drive so it is only in use for music and video stuff.
    It's a Seagate 7200.11 500GB, ST3500320AS, btw.
  2. Member zoobie's Avatar
    Feb 2005
    Florida
    there's usually an HDD analysis program by the mfg...maybe try running it and see what it says
  3. When a drive hits bad blocks it attempts to realign the heads. This usually makes a humming or buzzing noise and several clicks -- much louder than the normal sounds a drive makes. Perform a disk scan for errors with "scan for and attempt recovery of bad sectors" enabled. And yes, run the manufactures diagnostics.
  4. Banned
    Nov 2006
    USA
    Here are the initial Seagate diagnostic results:
    Short self test = fail
    Long self-test = fail
    Short random = pass
    Long random = still doing it.
    No sounds during test....yet. The fails are troubling, however, the drive seems to be working fine (plays mp3s from it good). It's been installed for 6 days.
  5. Member Number Six's Avatar
    Mar 2008
    I would return it for warranty replacement - it can't be trusted for reliability.
    "I will not be pushed, filed, stamped, indexed, briefed, debriefed, or numbered! My life is my own" - the Prisoner
    (NO MAN IS JUST A NUMBER)
    be seeing you ( RIP Patrick McGoohan )
  6. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    Short random = pass
    As already mentioned return the defective hard drive. Return it to Seagate or where you bought it from.
  7. I agree with the others. Since it's a new drive return it and get another.
