After ripping dvd to vcd the audio is very quiet. Should I use the nomalise option in dvd2avi? Will this increase the volume or just make the entire movie the same volume?
What software are you using to encode? Personally I encode my audio and video separately and use bbMPEG to mux. This way i can use the best tools (beSweet currently) for getting the best audio quality.
If your using TMPGenc to load the wav file that DVD2AVI makes, goto the Audio options and click the normalize options there, or you could try the normalize option in DVD2AVI. Personally, I would just use BeSweet :)
Recovering quiet audio
By ReedJohansson in forum AudioReplies: 6Last Post: 20th Mar 2012, 05:03 -
VOB2MPG Quiet Audio
By gfinlay in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 1st Apr 2010, 03:28 -
TSmuxer Audio Trouble - extremely quiet audio (AC3)
By johnp51 in forum Blu-ray RippingReplies: 7Last Post: 24th Sep 2009, 04:57 -
Normalise audio over several divx files
By yurkyurk in forum Video ConversionReplies: 1Last Post: 11th Oct 2008, 18:38 -
Front panel audio gone quiet all of a sudden
By specane in forum AudioReplies: 8Last Post: 5th Aug 2008, 10:02
