I used dvd shrink to save a movie, opened the vob files in VideoRedo Plus and then saved them as an .mpg with the ac3 audio converted to wav. Then I opened the mpg files in Studio 11 and there are missing sections inbetween each mpg file. About 1 second is missing inbetween each file.
What can I do to prevent this?
mpeg-2 has gops. unless you cut on a I frame there will be missing pieces.
use shrink to extract movie only with just the one audio you want. then use vob2mpeg to join and convert all those vobs into 1 mpg.--
Converting dvd with multi sections
By Peter1954 in forum Video ConversionReplies: 1Last Post: 14th Dec 2011, 05:42 -
.mpg file suddenly missing first 30 seconds.
By John97 in forum Newbie / General discussionsReplies: 1Last Post: 18th Nov 2010, 16:17 -
Joining two VOB sections from a DVD.
By jnetty99 in forum EditingReplies: 10Last Post: 14th Jul 2010, 19:36 -
Either sections of my video tape are missing or my VCR keeps skipping bits?
By contactadam2002 in forum Capturing and VCRReplies: 3Last Post: 12th Dec 2009, 17:02 -
Ripping A DVD with 3 sections into 1 .AVI
By Blue_3 in forum DVD RippingReplies: 6Last Post: 20th Mar 2008, 15:48
