Hi all,
I'm trying to install VirtualDub (1.8.6) with Deshaker plugin (2.4) on my mom's Windows Vista computer. VirtualDub is copied into the C:\Program Files\VirtualDub folder, and the Deshaker plugin in C:\Program Files\VirtualDub\Plugins.
However, when opening the filters dialog in VirtualDub, there is no Deshaker plugin listed. And trying to load it manually, I get the following error message:
(I realize now, that I forgot the check the event log.) But I can't find any references to this error on internet. I've turned off UAC in the hopes that would help, but it didn't. I've also tried loading the plugin from her "My Documents" folder, but that gave the same error message (but with the My Document path, of course).Cannot load plugin module "C:\Program Files\VirtualDub\Plugins\Deshaker.vdf": The application has failed to start because it's side-by-side configuration is incorrect. Please see the application event log for more detail.
Does anybody have any idea what the problem is here?
Thanks, Peter
Did you check this. It is from download web site.
I guess this pack is for XP so you may have to find one for Vista, if it exist.Download Deshaker and place Deshaker.vdf under the VirtualDub plugins directory and restart VirtualDub.
Important: If VirtualDub reports an error or if it can't load Deshaker correctly, you're most likely missing some required files. In that case, simply install the Microsoft Visual C++ 2005 SP1 Redistributable Package. -
Exact same problem here. Installing the MSVC++ Redistributable did indeed solve the problem. Thanks tinker!
Player to play 2 separate videos side by side for 3D effect ?
By andy15star in forum Software PlayingReplies: 9Last Post: 21st Jan 2012, 12:52 -
How Create ACHD side by side compatible with Panasonic 3D Cam and HDTV?
By castana in forum Video ConversionReplies: 7Last Post: 25th Jul 2011, 15:47 -
Are flash to dvd converters still on the "oohhhhkaaaay" side?
By snafubaby in forum Newbie / General discussionsReplies: 2Last Post: 31st May 2011, 08:02 -
[solved]3d side-by-side capture and conversion to anaglyph using VirtualDub
By jumpjack in forum Capturing and VCRReplies: 21Last Post: 13th Apr 2011, 19:23 -
Is the panasonic dmres46v a seudo svhs side-by-side player/recorder?
By yoda313 in forum RestorationReplies: 8Last Post: 17th May 2010, 08:09
