I got an LG DVD Recorder DR389. We used it to record videos from our videocamcorder since it's old school. We were able to transfer and record to a DVD but it won't play in my laptop. I don't know why. I tried to play the recorded DVD with my LG DVD Recorder and it works. Just won't work in my laptop tho. does anyone know why? any one pls help! thanks.
Did you finalize the disc ??
If they are not finalized on the recorder they were made on they will show up as blank on most other drives. -
I believe I have because I tried playing it in the DVD Recorder and it works fine. Any ideas?? Thanks.Originally Posted by Noahtuck
Test it in something other than the recorder. The recorder will be able to play the discs even if they aren't finalized.
If cameras add ten pounds, why would people want to eat them? -
It won't play in other recorders. It should be finalized because the recorder shows that the disc is being finalized before you are able to eject it. I'm really confused.Originally Posted by Ai Haibara
can anybody tell me if it has something to do with the DISC RECORD MODE. It is currently in XP. There are also SP, LP, EP, MLP. Will that make a difference?
how do you tell if the disc has been finalized? and if not, how do finalize the disc?
i found it already! thanks so much guys for the help!!! much appreciated.
store bought dvd won't play in laptop or pc, can't copy
By ghola in forum DVD RippingReplies: 11Last Post: 8th Mar 2012, 17:17 -
recorded dvd won't play on computer or other players??
By wundahoss in forum Newbie / General discussionsReplies: 6Last Post: 9th Jan 2011, 17:55 -
DVD Won't play past menu on laptop
By DVDLovers in forum Newbie / General discussionsReplies: 4Last Post: 11th Jan 2008, 13:24 -
DVD-9 disc won't play on my laptop
By Yep in forum Software PlayingReplies: 6Last Post: 13th Nov 2007, 06:51 -
DVD Recorded discs won't play on Laptop!! ):
By SteveMKIIDub in forum Software PlayingReplies: 11Last Post: 21st May 2007, 18:24
