I am trying to encode an mpeg4 movie file that is 1.05 GB to be an MPEG2 file so that I can burn it to DVD. The file encodes almost instantly and there is no file when done. Here is the information:
Encoding started on Thu Dec 11 12:07:27 EST 2008
/bin/sh: line 1: /Library/Application Support/ffmpegX/mpeg2enc: Malformed Mach-o file
movtoy4m
Copyright 2002-2006 Johan Lindström
All rights reserved..
INFO: [yuvscaler] yuvscaler 1.9.0 (15-02-2004) is a general scaling utility for yuv frames
INFO: [yuvscaler] (C) 2001-2004 Xavier Biquard <xbiquard@free.fr>, yuvscaler -h for help, or man yuvscaler
INFO: [yuvscaler] input: frame size: 720x480 pixels (518400 bytes)
INFO: [yuvscaler] input: chroma: 4:2:0 JPEG/MPEG-1 (interstitial)
INFO: [yuvscaler] input: frame rate: 30000/1001 fps (~29.970030)
INFO: [yuvscaler] input: interlace: none/progressive
INFO: [yuvscaler] input: sample aspect ratio: 1:1
INFO: [yuvscaler] from 720x480, take 720x480+0+0, NOT_INTERLACED/PROGRESSIVE
INFO: [yuvscaler] scale to 720x480, 720x480 being displayed
INFO: [yuvscaler] Scaling uses the RESAMPLE algorithm,
INFO: [yuvscaler] frame rate: 29.970 fps
INFO: [yuvscaler] Scaling ratio for width is 1 to 1
INFO: [yuvscaler] and is 1 to 1 for height
INFO: [yuvscaler] Specific downscaling routing number 4
Originally Posted by chack311
Alternatively, try this zipped copy, as .zip files cause less confusion (for both users and browsers).
How do you make a simple html file showing list of files in a folder?
By yoda313 in forum ComputerReplies: 2Last Post: 6th Mar 2010, 20:12 -
2 Problems in WE Re: Showing Video File Info In Columns and Mouse Hover
By OllyPomm in forum ComputerReplies: 5Last Post: 13th Aug 2009, 19:56 -
Subtitles not showing up in preview/file with Gordian Knot - help?!
By amiableakuma in forum Video ConversionReplies: 1Last Post: 7th Feb 2009, 17:47 -
SRT file not showing english? apparently theres multiple languages...
By wyteone in forum SubtitleReplies: 3Last Post: 4th Dec 2008, 09:01 -
won't encode full file, and will only do certain file formats
By GregDz in forum ffmpegX general discussionReplies: 0Last Post: 21st Jun 2008, 21:27
