EXPERIMENTAL : author DVD on CD
THIS is my first post...
NOTE : you can ignore this tips if you prefer standard DVD authoring
##software requirements:TMPGEnc DVD author v1.6.34.89
##"higher than this version only support DVD disc"
If you have small amount of videos (smaller than 600mb) & need to convert it to DVD,why don't you use this guide....![]()
If you feel that you'll waste lots of unused space when using DVD-R then you can use CD-R(CD-RW not supported).
1. First,convert all your videos with your MPEG encoder(TMPGEnc Express recommended,use MPEG2 file output )
2. Watch for the total MPEG2 files size resulted...is it fit on 1 CD (max.600mb,smaller recommended)
3. Load the MPEG2 results to TMPGEnc DVD Author v1.6.34.89,then create menus,chapters and stuff..
4. Then create and burn the DVD result using the CD-R you have inserted into your DVD writer..
5. DONE
6. PLAY the "DVD on CD" on your DVD player....
7. The DVD player may not recognize it as DVD,but it will play.....
P.S. :- this is only for the experimentalist
- the results may vary depends on your DVD player
- the TMPGEnc DVD Author may warn you about DVD standard.you can ignore this
- use only this TMPGEnc internal burner(Nero/others will refuse DVD structure written on CD)
- Even the new version of TMPGEnc DVD Author also refuse to write DVD structure on CD
- I will provide screenshot if needed (next time)
- I use this method several times with mostly successful
Do NOT crosspost. One post per subject is sufficient on this site. Read the rules.
This is nothing new or amazing.
It is called a "MiniDVD"
You don't have to use TDA or any specific software.Originally Posted by vidholic
All you have to do is author a dvd video structure that will fit on a cdr and burn it.
Not all players will play a MiniDVDOriginally Posted by vidholic
WRONG!!!! Nero even has a selection to choose to make a MiniDVD & i have burned them using other programs as well.....Originally Posted by vidholic
Thats why you do NOT use TDA to burn dvd's or cd'sOriginally Posted by vidholic
I did this several times years ago, back when CD-Rs were cheap and DVD-Rs were expensive (relatively) and my home video files were less than 700 MB. I was using DVD-Lab to author back then. I can't remember what I used to burn the files--either Windows XP or the NTI software that came with my laptop.
Why would anyone want to do this today? It only worked on about half the DVD players where I tried it (sample size of 4), and computers (if they had DVD video software--not all did). The future seems more likely to lose backward support for CD-R than DVD-R, and the price isn't much different. It's just DVD files burned to a CD-R. It works, but why bother? -
Ha Ha Ha, that guy got owned.
Jagabo, please do not reply to this post. Thank you. -
Coming Next: How To Put Audio On A Floppy Disc.
Nothing wrong with this post and Noahtuck correcting him/her,outdated but some people might find it handy.
Non-experimental thread on best known VHS > BD / DVD methods
By _yo_wasup_ in forum Newbie / General discussionsReplies: 14Last Post: 17th Feb 2010, 16:28 -
FFmpeg 64-bit autobuilds (experimental)
By Chris K in forum Latest Video NewsReplies: 0Last Post: 25th Jan 2010, 06:02 -
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 12:10 -
New experimental TS cutting software for MPEG-2 and H.264 Transport Streams
By Nukster in forum EditingReplies: 2Last Post: 14th May 2009, 10:16 -
By vidholic in forum User guidesReplies: 2Last Post: 11th Dec 2008, 11:26
